6 à 8 secondes, c'est en effet beaucoup pour une simple détection avec une seule activation liée. Comme vous êtes sur un RPi5, le délai vient probablement plutôt du traitement côté Raspberry ou de l'automatisation que de la caméra elle-même. Vous utilisez quoi exactement pour piloter la lampe ? Home Assistant, Frigate, Motion ou autre ? Et quand vous parlez de détection infrarouge, c'est bien la détection de mouvement de la caméra Dahua que vous utilisez, ou est-ce que vous passez par un capteur tier branché sur le Raspberry ?WWDParts a modifié sa photo de profilWWDParts a rejoint la communautéLa semaine dernière
Buy Real Registered Documents: WhatsApp: +49 15511 029239 or WhatsApp: +1 289 297 4309. How to get a passport | Fastest way to get a passport | Emergency Passport Services | Same day Passport Service | Passport Renewal Cost | Lost Passport Replacement | Birth Certificates | Drivers License We also provide Canadian Citizenship and U.S. citizenship. Second Passport with Proof of Citizenship We are the top choice for exceptional and distinctive production registered nationality documents. With many years of experience working in a powerful network of agencies with superior global connections. We also provide national ID cards, driver’s licenses, residence permits, and passports for the UK, Canada, South Korea, Vietnam, and the Netherlands. Additionally, we offer social security numbers, Green Cards, various types of certificates, and proof-of-citizenship documents. Inquire with us about NEBOSH course fees. How to get a second passport? Buy French Passport or Australian Passport [Whatsapp +49 15511 029239 or +1 289 297 4309]. We also provide German and Italian Biometric Passports [WhatsApp: +1 289 297 4309]. E-visas, national ID cards, driver’s licenses, and residence permits are also available for purchase. We offer Passports for Australia, the United States, Japan, the UK, South Korea, and China, as well as Diplomatic passports. ✪-✅ WhatsApp: +1 289 297 4309 ✪-✅ Whatsapp +49 15511 029239 ✪-✅ Email: [email protected] ✪-✅ Telegram: @powerweipi ✪-✅ Signal: powerweipi.56 ✪-✅ Session ID: 056d7b37a310ecc59afa801a467fbb3b298f86b4050acb34ef56b9d7268f8ab41c Various types of documents online, including passports, national ID cards, driver’s licenses, green cards, residence permits, IELTS score reports, work permits, proof of citizenship, Canadian residence permits, Canadian citizenship documents, Canadian ID cards, and a wide range of other identification documents—all authentic-looking and valid. Purchase passports online ([email protected]), including those for Australia, the United States, China (Telegram: @powerweipi), Canada, Malaysia, Hong Kong, and Taiwan, as well as valid biometric passports and passports from various European countries. We also provide passports registered in government databases, Canadian Permanent Resident cards ("Maple Leaf cards"), U.S. citizenship documents, and U.S. green cards. Wondering where to apply for a passport? ([Whatsapp +49 15511 029239 or +1 289 297 4309) Additionally, we offer services for purchasing driver’s licenses and renewing passports online. Purchase TOEFL, IELTS, and TOEIC exam scores. We also provide services related to Canadian and U.S. citizenship, Canadian TCF/TEF/CELPIP/CELTA certificates, Canadian permanent residency, direct immigration to Canada, driver’s licenses, identification documents, U.S. green cards Social Security Numbers (SSN), work permits, various forms of identification, National Insurance cards, National Identity Numbers (NIN), Social Insurance Numbers (SIN), marriage certificates, and birth certificates. Apply for a Passport Online Passport Application Requirements Passport Processing Time Fastest Way to Get a Passport Passport Renewal Cost Lost Passport Replacement Emergency Passport Services Same-Day Passport Appointment Passport Application Assistance How to get a U.S. passport U.S. passport application Apply for a passport online U.S. passport requirements U.S. passport processing time Expedited U.S. passport U.S. passport renewal cost Lost U.S. passport replacement Emergency passport appointment Same-day passport service Cheapest country to buy a second passport Best citizenship by investment countries in 2026 Dominica citizenship cost Grenada passport investment requirements Caribbean citizenship programs comparison How to get Turkish citizenship through investment Best second passport for American citizens Citizenship by investment for families Countries offering passports without residency How can I legally obtain a second passport? Which countries offer citizenship by investment? How much does a second passport actually cost? What should I know before applying for a passport? How do I identify legitimate passport and citizenship services? Buy a second passport legally Second passport for US citizens Citizenship by investment Cheapest citizenship by investment Best countries for second citizenship Countries offering citizenship by investment Dual citizenship requirements Caribbean citizenship programs Passport investment programs Citizenship by descent Best second passport for travel How to get a passport Apply for a passport online Passport application requirements Fastest way to get a passport Emergency passport services Same-day passport appointment Passport renewal cost Passport processing time Lost passport replacement Passport application assistance Can you legally buy a passport without citizenship? Which countries sell citizenship? How much does it cost to get a second passport? What is the easiest country to get citizenship in? Can Americans legally have two passports? Which passport gives you the most visa-free access? Can I get citizenship through my grandparents? Is citizenship by investment legitimate? How long does it take to get a second passport? What is the difference between a Golden Visa and citizenship by investment? How to get a second passport Best countries for citizenship by investment Countries where you can buy citizenship legally Cheapest citizenship by investment How to get a passport fast Second passport for US citizens Best countries for dual citizenship Citizenship by descent requirements How much does a second passport cost? Countries with visa-free travel Buying a passport Buy a passport online, how to get a passport, where can I buy a passport? Fast passports Fastest way to get a passport, emergency passport, same-day passport Passport costs How much does a passport cost? Cheapest passport to get Second citizenship How to get a second passport, best second citizenship programs Investment passports Buy citizenship by investment, countries that sell citizenship Passport requirements What documents do I need for a passport? Passport renewal How to renew a passport, expedited passport renewal International mobility World's most powerful passports, passports with visa-free travelabrimlinkon a rejoint la communauté- Domotique en panne : diagnostiquer le réseau avant de tout réinitialiser
Bonjour, je me suis inscrit car j'ai pas mal d'objets connectés à la maison et je viens de mettre home assistant en place sur un mini pc Lenovo. J'aurais besoin de parcourir ce forum pour m'instruire et me renseigner pour comprendre ce système qui pour l'instant me paraît compliqué. J'ai également fabriquer un anti brouilleur d'onde relié à mon alarme avec esphome. Bonne journée BenoîtBenji62 a rejoint la communauté- Problème avec bridge Cozytouch
Bonjour à tous Je me permets de poster ici, car depuis que j’ai essayé de remettre en route mon bridge cozytouch pour l’hiver, il ne se reconnecte plus au wifi. J’ai remis à zéro la bestiole et retentée une bonne 20aine de fois de refaire l’association wifi, mais aucun réseau visible systématiquement, que ce soit sur ma box, ou en partage de connexion. Je suis bien en 2,4ghz, à 1m. de la box, rien n’y fait. Le bridge se met bien en mode démarrage de configuration (clignotement bleu) , l’app cozytouch Android détecte bien le bridge en bluetooth, mais quand il recherche les signaux wifi, rien de rien. Du coup j’ai ouvert l’animal, et j’ai l’impression qu’il manque un composant entre le chipset wifi et l’antenne, mais j’ai pas le niveau pour en être sûre. Je vous mets les photos, si quelqu’un a déjà ouvert son bridge ou a eu ce genre de problème, je suis preneuse. Merci d’avoir lu mon message.Ephemere22 a commencé à suivre Problème avec bridge CozytouchEphemere22 a rejoint la communauté- Présentation
Dominique, retraité depuis déjà un bon moment, électricien d'abord dans l'industrie puis dans les travaux publics. Ca fait un moment que je ne suis plus sur le terrain, donc je n'ai plus suivi les évolutions, la domotique pour moi est un sujet que je ne maitrise pas. J'ai chez moi un volet roulant avec ouverture fermeture programmé, mais dont le fonctionnement commence à me faire des caprices. J'aimerai étudier un fonctionnement plus moderne, voir toutes les options possibles. Au plaisirs de vous lire, avec mes remerciements.domi59 a rejoint la communautéFracb a rejoint la communautéPuma50 a commencé à suivre Home Assistant- Connexion caméra vidéo dôme PEO sur NVR coaxial
Si la caméra dôme est une caméra IP, le simple adaptateur RJ45/BNC ne pourra pas fonctionner. Un balun ne convertit pas un flux réseau IP en signal vidéo analogique : il sert seulement à transporter un signal analogique sur un câble Cat 5/6, avec normalement un balun à chaque extrémité. Il faudrait vérifier si votre enregistreur est hybride et accepte des caméras IP. Si oui, la caméra doit être connectée au même réseau que l’enregistreur, puis ajoutée depuis son menu, éventuellement via ONVIF. Sinon, il faudra utiliser un enregistreur IP séparé ou choisir une caméra analogique compatible avec le format du système existant. Le modèle exact de la caméra et celui de l’enregistreur permettraient de confirmer la bonne solution.- [Concours] Une enceinte Faller OSKAR Classic à gagner (249 €) 🎁
Salut à tous ! Un petit partage qui sort un peu du cadre de la domotique, mais qui pourrait intéresser certains d'entre vous :) J'ai récemment testé la Faller OSKAR Classic, une enceinte assez particulière qui permet de mieux entendre les dialogues à la télévision sans avoir à monter le volume. Au départ, j'étais assez sceptique, car le produit est surtout présenté comme une solution pour les seniors ou les personnes ayant des difficultés auditives. Mais finalement, j'ai découvert un usage auquel je n'avais pas pensé : regarder mes films et séries sans casque, tout en évitant de déranger le reste de la famille ! L'enceinte posée à côté de moi, je profite parfaitement des dialogues, alors qu'à 3 mètres on entend à peine la télévision. Plutôt bluffant ! J'ai publié un test complet pour ceux que ça intéresse, avec mon retour d'expérience, les avantages et les limites du produit. Et surtout, j'organise un petit concours pour faire gagner un exemplaire neuf de cette enceinte, d'une valeur de 249 € ! 🎁 🍀 Vous avez jusqu'au 29 novembre à minuit pour participer. 👉 Le test et le concours sont ici : Maison et DomotiqueCONCOURS / Test Faller OSKAR Classic : cette enceinte m'a...Test du Faller OSKAR Classic : une enceinte qui améliore les dialogues TV sans déranger l'entourage. Notre avis, ses limites et un concours ! Voilà, si ça peut faire un heureux parmi les membres du forum, ce sera avec plaisir ! Et je suis curieux de savoir si certains utilisent déjà ce genre de solution pour profiter de leur TV sans déranger tout le monde 😊- Réseau Zigbee Legrand totalement perturbé après une coupure électrique – problème de routage ?
Bonjour, Je rencontre un problème assez complexe sur mon installation Legrand with Netatmo, qui fonctionnait parfaitement avant une coupure électrique. Installation : Environ 10 volets roulants filaires Legrand connectés (réf. 067726). Passerelle Legrand Control au tableau électrique. Variateur connecté, micromodule d'éclairage et commandes sans fil. Tests complémentaires réalisés avec une clé Zigbee et Zigbee2MQTT. Depuis la coupure : Tous les volets fonctionnent parfaitement en commande locale. Certains équipements sont devenus injoignables dans Home + Control. tentative de récupérationen coupant et en rallumant tous les element ensemble Après réinitialisation et nouvel appairage, ce sont systématiquement les mêmes volets qui rejoignent le réseau. D'autres équipements semblent s'associer, mais restent injoignables. Tests avec Zigbee2MQTT : Les équipements peuvent communiquer correctement lorsque la clé Zigbee est placée à proximité. À distance, les communications échouent. La carte du maillage ne remonte pas correctement les informations. Des erreurs ZIGBEE_SEND_UNICAST_NO_ROUTE ont été observées. Je soupçonne un problème de routage ou de reconstruction du maillage après la coupure électrique. Mes questions : Avez-vous déjà rencontré ce problème avec des équipements Legrand with Netatmo ? Une coupure électrique peut-elle laisser certains routeurs Zigbee dans un état où ils ne relaient plus correctement les messages ? Existe-t-il une procédure permettant de reconstruire proprement les routes et les tables de voisinage sans réinitialiser systématiquement tous les équipements ? Les commandes filaires Legrand 067726 participent-elles réellement au routage Zigbee pour les autres équipements ? Quels diagnostics ou journaux permettraient d'identifier précisément l'équipement qui bloque les communications ? Je cherche surtout à comprendre la cause technique, car les réinitialisations répétées n'ont pas résolu le problème. Merci pour votre aide.- Home Assistant Connect AUX-2 : un nouveau couteau suisse domotique à seulement 59 € !
Salut à tous ! Home Assistant vient de dévoiler un nouveau boîtier qui devrait intéresser pas mal de monde ici : le Connect AUX-2. À première vue, on pourrait penser à un simple adaptateur audio, mais il embarque en réalité un paquet de fonctionnalités intéressantes pour nos installations domotiques ! 🎵 Audio multiroom : possibilité de connecter une ancienne chaîne Hi-Fi ou un ampli à Music Assistant, avec synchronisation des enceintes via Sendspin. 📺 2 ports RS-232 : pour piloter certains téléviseurs, amplificateurs, vidéoprojecteurs, etc. directement depuis Home Assistant, sans forcément passer par le cloud. ☀️ RS-485 / Modbus : avec un adaptateur USB, on peut récupérer les données de certains onduleurs solaires, batteries, pompes à chaleur et autres équipements énergétiques. De quoi imaginer pas mal de scénarios pour optimiser son autoconsommation ! 📡 Z-Wave : possibilité de brancher un contrôleur ZWA-2 et de le déporter ailleurs dans la maison, à un emplacement plus favorable que la baie informatique. 🔵 Proxy Bluetooth : pour étendre la couverture des capteurs et autres équipements Bluetooth Low Energy. ⚡ Ethernet PoE : un seul câble pour l'alimentation et la communication réseau, ce qui est franchement pratique ! Le tout fonctionne sous ESPHome, avec un firmware ouvert et personnalisable. Il dispose même d'un connecteur Grove pour les amateurs de bidouille. Quelques limites tout de même : le Zigbee via ZBT-2 est encore expérimental, Thread n'est pas officiellement pris en charge et le port USB ne fonctionne pas avec tous les périphériques. Le prix annoncé est de 59 €, ce que je trouve plutôt intéressant compte tenu des possibilités. J'ai fait un dossier assez complet sur Maison et Domotique, en reprenant les annonces officielles, la conférence de lancement et surtout les différents usages possibles en domotique : Maison et DomotiqueHome Assistant Connect AUX-2 : le couteau suisse à 59 € q...Home Assistant Connect AUX-2 réunit audio multiroom, RS-232, Modbus, Z-Wave, Bluetooth et PoE. Découvrez toutes ses possibilités pour 59 €. Je devrais recevoir un exemplaire prochainement pour réaliser un test et voir ce que tout cela donne en pratique. Certains parmi vous envisagent de l'acheter ? Vous l'utiliseriez pour quoi ? De mon côté, la partie RS-485/Modbus m'intéresse particulièrement pour la gestion de l'énergie, mais la possibilité de déporter un contrôleur Z-Wave en PoE est également très séduisante. Et je suis curieux de voir ce que donnera la partie audio avec Music Assistant !- Homme assistant green et smlighit slzb mr1u
Bonjour Je me lance dans l'installation de la domotique chez moi, et je galère pour configurer mon materiel. Pour l'instant je n'ai pu rien intégrer. le module zigbee à gauche de l'écran me met un message d'erreur.LAGARDE a commencé à suivre Homme assistant green et smlighit slzb mr1uAvant
- 💡 Philips Hue : Zigbee et Matter over Thread peuvent désormais fonctionner simultanément !
Salut à tous ! Petite nouveauté intéressante du côté de Philips Hue, qui vient de déployer une mise à jour plutôt prometteuse pour ses ampoules de dernière génération. Avec le firmware 1.164.2, les ampoules compatibles peuvent désormais utiliser Zigbee et Matter over Thread simultanément ! 🎉 C'est une évolution intéressante, puisqu'on peut conserver les avantages de l'écosystème Zigbee de Hue tout en profitant d'une connexion directe via Matter over Thread. La mise à jour apporte également la compatibilité Matter 1.4.1 et l'éclairage adaptatif Apple via Matter. Pour ceux qui utilisent Home Assistant, Jeedom ou plusieurs écosystèmes domotiques, cette coexistence des protocoles ouvre des perspectives intéressantes. Je me pose notamment une question : les ampoules peuvent-elles également jouer le rôle de routeurs Thread et contribuer au maillage du réseau, tout en restant connectées en Zigbee ? Ce serait un vrai plus pour améliorer la couverture Thread dans une maison ! En parallèle, Philips Hue a également publié une mise à jour pour sa nouvelle HDMI Sync Box 4K, avec quelques améliorations de stabilité. J'ai détaillé toutes ces nouveautés dans un article : Maison et DomotiquePhilips Hue libère Thread sur ses nouvelles ampoules sans...Philips Hue déploie Matter 1.4.1 et active l’utilisation simultanée de Zigbee et Matter over Thread sur ses nouvelles ampoules. La Sync Box 4K reçoit également une mise à jour. Certains parmi vous ont déjà reçu cette mise à jour ou testé le fonctionnement simultané Zigbee / Thread ? Curieux d'avoir vos retours, notamment sur l'intégration avec Home Assistant et le comportement du réseau Thread ! 🙂- Problème avec iphone
Bonjour j ai partagé 1 appareil avec 1 iphone. Il a bien reçu 1 notification de partagé mais je ne vois pas l appareil a l ecran- Connexion caméra vidéo dôme PEO sur NVR coaxial
Bonjour à tous, J'ai actuellement un système de vidéo surveillance avec un NVR H.265+, prises de connexion BNC, et des caméras sur coaxial et prises BNC qui fonctionnent bien. Je souhaite rajouter une caméra dôme qui elle est avec une connectique RJ45 plus une alimentation DC 12volt. j'ai tiré 50m de câble catégorie 6 et mis une alimentation 12 volts proche de la caméra dôme pour sa motorisation. J'ai mis un adaptateur balun sur la prise BNC du NVR, mais quand je connecte la prise RJ45 du dôme sur le balun pas d'image. Quelqu'un a-t-il une suggestion pour solutionner ce problème ? Par avance merci ! Jean-louisJLL a commencé à suivre Connexion caméra vidéo dôme PEO sur NVR coaxial- Allumer et éteindre une caméra
Il n'est pas possible d'éteindre et de rallumer une caméra sur Tuya directement, mais seulement de les mettre en veille. Si une caméra devait être totalement éteinte, la connexion serait perdue définitivement, et donc son accès à distance en même temps. Cependant, il est possible de mettre les caméras en veille, un système qui la coupe de son état d'alerte, et dans ce cas elle va très peu consommer. Nous n'avons que des caméras autonomes de notre côté sur TUYA, donc je vous confirme ça en me basant sur ce modèle solaire uniquement. J'avoue ne pas pouvoir le confirmer avec les caméras qui fonctionnent en IP sur secteur, il y a peut être davantage d'options. A surveiller- HA en wifi peut-il être piraté ?
Bonjour, Ma réponse n'est pas passée. Merci d'avoir répondu. Pour Wifi ok. Pour le matériel, je n'ai rien acheté même si je commence à avoir une petite idée. Référence AIRZONE, la bête (caisson 1/2 m3) est suspendue dans les combles perdues. Il y a un petit module sur le côté avec antenne qui émet en Wifi à la maison accessible via l'appli sur portable ou un boîtier de commande dans chaque pièce mais qui dévore les minies piles/batteries. Quand on s'absente, on pouvait se connecter via l'appli via le cloud AIRZONE pour programmer le chauffage (guère la clim) de la PAC. Maintenant que c'est devenu payant alors que c'était gratuit (présentation par le vendeur qui a orienté mon choix) je pense acheter Nabu Casa box domotique Home Assistant green couplé à Dongle USB Zigbce Connect. Mon projet est-il correct ? A vérifier si ça va fonctionner... Le tout sera posé auprès de la FreeBox. Merci de m'aiguiller. Cordialement, Claude- Home Assistant 2026.11 est disponible : une grosse mise à jour avec plein de nouveautés ! 🚀
Salut à tous ! La mise à jour Home Assistant 2026.11 vient de sortir, et cette version de novembre est particulièrement riche, avec près de 6 000 contributions et 38 nouvelles intégrations ! J'ai pris le temps de décortiquer les notes officielles et plusieurs présentations des développeurs pour faire un tour complet des nouveautés. Au programme, pas mal de choses intéressantes : 🏠 Des tableaux de bord automatiques : les sections peuvent désormais se remplir et s'actualiser toutes seules en fonction des appareils et des pièces. Pratique quand on ajoute régulièrement de nouveaux équipements ! ⚙️ Des automatisations plus souples : on peut enfin exclure certains appareils ou certaines pièces d'une action. Par exemple, éteindre toutes les lumières du rez-de-chaussée, sauf celles du salon. Personnellement, c'est une des nouveautés que je trouve les plus utiles ! 🔎 Un meilleur suivi des actions : un nouvel historique permet de retrouver qui ou quoi a déclenché une commande. Fini de chercher pendant des heures pourquoi une lumière s'est allumée toute seule 😅 🎥 L'audio bidirectionnel fait son apparition pour certaines caméras Reolink et Matter, encore en mode expérimental. 📡 LoRaWAN et Zigbee Green Power rejoignent également les protocoles pris en charge, avec notamment des possibilités intéressantes pour les capteurs longue portée et les interrupteurs sans pile. 🛍️ HACS devient officiellement Marketplace, directement intégré à Home Assistant, avec une migration automatique des installations existantes. 🔋 Et il y a aussi des améliorations pour le suivi énergétique, les sauvegardes, les journaux de diagnostic et la gestion des statistiques. Attention tout de même à la refonte du nommage des entités, qui pourrait demander quelques ajustements sur les dashboards personnalisés. Les identifiants techniques restent inchangés, mais certains noms affichés évoluent. J'ai regroupé toutes ces nouveautés, avec des explications et des exemples concrets, dans un dossier complet : Maison et DomotiqueHome Assistant 2026.11 : automatisations plus intelligent...Home Assistant 2026.11 arrive avec 38 intégrations, HACS intégré, des automatisations simplifiées, des dashboards automatiques et bien plus. Certains ont déjà installé cette version ? Vous avez rencontré des soucis, notamment avec les dashboards ou les intégrations HACS ? Et surtout, quelle nouveauté vous semble la plus intéressante ? De mon côté, les exclusions dans les automatisations et les sections automatiques me plaisent beaucoup ! 😁- HA en wifi peut-il être piraté ?
