Posté(e) 5 juin5 juin bonjoursmon Z2M a arrêter de fonctionner lors d'un redémarrage et impossible de comprendre la raisonj'utilise un coordinateur Zigbee SLZB-06Utout fonctionnait parfaitement avantet meme en faisant des backup cela ne fonctionne pasEst-ce que vous avez une solution ?merciCordialement[18:05:06] INFO: [32mPreparing to start...[0m[18:05:06] INFO: [32mSocat not enabled[0m[18:05:06] INFO: [32mStarting Zigbee2MQTT...[0mStarting Zigbee2MQTT without watchdog.[2026-06-05 18:05:07] [32minfo[39m: z2m: Logging to console, file (filename: log.log)[2026-06-05 18:05:08] [32minfo[39m: z2m: Starting Zigbee2MQTT version 2.11.0 (commit #unknown)[2026-06-05 18:05:08] [32minfo[39m: z2m: Starting zigbee-herdsman (10.1.0)[2026-06-05 18:05:08] [32minfo[39m: zh:zstack:znp: Opening TCP socket with 192.168.10.20:6638[2026-06-05 18:05:08] [32minfo[39m: zh:zstack:znp: Socket connected[2026-06-05 18:05:08] [32minfo[39m: zh:zstack:znp: Socket ready[2026-06-05 18:05:08] [32minfo[39m: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload[2026-06-05 18:05:09] [32minfo[39m: zh:zstack:znp: Skip bootloader for CC2652/CC1352[2026-06-05 18:06:14] [31merror[39m: z2m: Error while starting zigbee-herdsman[2026-06-05 18:06:14] [31merror[39m: z2m: Failed to start zigbee-herdsman[2026-06-05 18:06:14] [31merror[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions[2026-06-05 18:06:14] [31merror[39m: z2m: Exiting...[2026-06-05 18:06:14] [31merror[39m: z2m: Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby (Error: AREQ - ZDO - stateChangeInd after 60000msat Object.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/utils/waitress.ts:68:23)at ZnpAdapterManager.beginCommissioning (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:376:31)at processTicksAndRejections (node:internal/process/task_queues:103:5)at ZnpAdapterManager.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:90:21)at ZStackAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:135:16)at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:146:29)at Zigbee.start (/app/lib/zigbee.ts:70:27)at Controller.start (/app/lib/controller.ts:117:29)at start (/app/index.js:156:5))at ZnpAdapterManager.beginCommissioning (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:378:23)at ZnpAdapterManager.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:90:21)at ZStackAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:135:16)at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:146:29)at Zigbee.start (/app/lib/zigbee.ts:70:27)at Controller.start (/app/lib/controller.ts:117:29)at start (/app/index.js:156:5) Modifié 5 juin5 juin par Beber54000
