Beber54000
  1. bonjours mon Z2M a arrêter de fonctionner lors d'un redémarrage et impossible de comprendre la raison j'utilise un coordinateur Zigbee SLZB-06U tout fonctionnait parfaitement avant et meme en faisant des backup cela ne fonctionne pas Est-ce que vous avez une solution ? merci Cordialement [18:05:06] INFO: [32mPreparing to start...[0m [18:05:06] INFO: [32mSocat not enabled[0m [18:05:06] INFO: [32mStarting Zigbee2MQTT...[0m Starting Zigbee2MQTT without watchdog. [2026-06-05 18:05:07] [32minfo[39m: z2m: Logging to console, file (filename: log.log) [2026-06-05 18:05:08] [32minfo[39m: z2m: Starting Zigbee2MQTT version 2.11.0 (commit #unknown) [2026-06-05 18:05:08] [32minfo[39m: z2m: Starting zigbee-herdsman (10.1.0) [2026-06-05 18:05:08] [32minfo[39m: zh:zstack:znp: Opening TCP socket with 192.168.10.20:6638 [2026-06-05 18:05:08] [32minfo[39m: zh:zstack:znp: Socket connected [2026-06-05 18:05:08] [32minfo[39m: zh:zstack:znp: Socket ready [2026-06-05 18:05:08] [32minfo[39m: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload [2026-06-05 18:05:09] [32minfo[39m: zh:zstack:znp: Skip bootloader for CC2652/CC1352 [2026-06-05 18:06:14] [31merror[39m: z2m: Error while starting zigbee-herdsman [2026-06-05 18:06:14] [31merror[39m: z2m: Failed to start zigbee-herdsman [2026-06-05 18:06:14] [31merror[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions [2026-06-05 18:06:14] [31merror[39m: z2m: Exiting... [2026-06-05 18:06:14] [31merror[39m: z2m: Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby (Error: AREQ - ZDO - stateChangeInd after 60000ms at Object.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/utils/waitress.ts:68:23) at ZnpAdapterManager.beginCommissioning (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:376:31) at processTicksAndRejections (node:internal/process/task_queues:103:5) at ZnpAdapterManager.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:90:21) at ZStackAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:135:16) at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:146:29) at Zigbee.start (/app/lib/zigbee.ts:70:27) at Controller.start (/app/lib/controller.ts:117:29) at start (/app/index.js:156:5)) at ZnpAdapterManager.beginCommissioning (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:378:23) at ZnpAdapterManager.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:90:21) at ZStackAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:135:16) at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:146:29) at Zigbee.start (/app/lib/zigbee.ts:70:27) at Controller.start (/app/lib/controller.ts:117:29) at start (/app/index.js:156:5)
