  2. Claudius a rejoint la communauté
  3. Arubinu a posté un message dans un sujet dans Sonoff
  4. BièreNard a posté un message dans un sujet dans Sonoff
  5. Arubinu a posté un message dans un sujet dans Sonoff
  7. Jack a posté un message dans un sujet dans Présentations des Membres
  8. Jack a posté un message dans un sujet dans Présentations des Membres
  9. BièreNard a posté un message dans un sujet dans Sonoff
    Bonjour Arubinu, ZHA est bien désactivé Mosquitto Broker est lancé : Spoiler s6-rc: info: service s6rc-oneshot-runner: starting s6-rc: info: service s6rc-oneshot-runner successfully started s6-rc: info: service fix-attrs: starting s6-rc: info: service fix-attrs successfully started s6-rc: info: service legacy-cont-init: starting cont-init: info: running /etc/cont-init.d/mosquitto.sh [11:50:51] INFO: SSL is not enabled cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0 cont-init: info: running /etc/cont-init.d/nginx.sh cont-init: info: /etc/cont-init.d/nginx.sh exited 0 s6-rc: info: service legacy-cont-init successfully started s6-rc: info: service legacy-services: starting services-up: info: copying legacy longrun mosquitto (no readiness notification) services-up: info: copying legacy longrun nginx (no readiness notification) s6-rc: info: service legacy-services successfully started [11:50:53] INFO: Starting NGINX for authentication handling... [11:50:54] INFO: Starting mosquitto MQTT broker... 2025-05-08 11:50:54: Warning: Mosquitto should not be run as root/administrator. 2025-05-08 11:50:54: mosquitto version 2.0.20 starting 2025-05-08 11:50:54: Config loaded from /etc/mosquitto/mosquitto.conf. 2025-05-08 11:50:54: Loading plugin: /usr/share/mosquitto/go-auth.so 2025-05-08 11:50:54: ├── Username/password checking enabled. 2025-05-08 11:50:54: ├── TLS-PSK checking enabled. 2025-05-08 11:50:54: └── Extended authentication not enabled. 2025-05-08 11:50:54: Opening ipv4 listen socket on port 1883. 2025-05-08 11:50:54: Opening ipv6 listen socket on port 1883. 2025-05-08 11:50:54: Opening websockets listen socket on port 1884. 2025-05-08 11:50:54: mosquitto version 2.0.20 running 2025-05-08 11:50:54: New connection from ::1:52932 on port 1883. 2025-05-08 11:50:54: Client <unknown> disconnected due to protocol error. s6-rc: info: service legacy-services: stopping 2025-05-08 11:50:56: mosquitto version 2.0.20 terminating 2025-05-08 11:50:56: Saving in-memory database to /data//mosquitto.db. [09:50:56] INFO: Service restart after closing [09:50:56] INFO: Service restart after closing s6-rc: info: service legacy-services successfully stopped s6-rc: info: service legacy-cont-init: stopping s6-rc: info: service legacy-cont-init successfully stopped s6-rc: info: service fix-attrs: stopping s6-rc: info: service fix-attrs successfully stopped s6-rc: info: service s6rc-oneshot-runner: stopping s6-rc: info: service s6rc-oneshot-runner successfully stopped s6-rc: info: service s6rc-oneshot-runner: starting s6-rc: info: service s6rc-oneshot-runner successfully started s6-rc: info: service fix-attrs: starting s6-rc: info: service fix-attrs successfully started s6-rc: info: service legacy-cont-init: starting cont-init: info: running /etc/cont-init.d/mosquitto.sh [11:51:05] INFO: SSL is not enabled cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0 cont-init: info: running /etc/cont-init.d/nginx.sh cont-init: info: /etc/cont-init.d/nginx.sh exited 0 s6-rc: info: service legacy-cont-init successfully started s6-rc: info: service legacy-services: starting services-up: info: copying legacy longrun mosquitto (no readiness notification) services-up: info: copying legacy longrun nginx (no readiness notification) s6-rc: info: service legacy-services successfully started Voici la config de Zigbee2MQTT : Spoiler socat enabled: false master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777 slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5 options: "-d -d" log: false mqtt serial port: >- /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_c2a587c3d549ef118f13d58cff00cc63-if00-port0 adapter: ember La présentation du module : au lancement de Zigbee2MQTT ... le message d'erreur : et le journal du lancement de Zigbee2MQTT ... Spoiler [19:10:08] INFO: Preparing to start... [19:10:08] INFO: Socat not enabled [19:10:08] INFO: Starting Zigbee2MQTT... Starting Zigbee2MQTT without watchdog. [2025-05-09 19:10:13] info: z2m: Logging to console, file (filename: log.log) [2025-05-09 19:10:13] info: z2m: Starting Zigbee2MQTT version 2.3.0 (commit #unknown) [2025-05-09 19:10:13] info: z2m: Starting zigbee-herdsman (4.0.0) [2025-05-09 19:10:14] info: zh:ember: Using default stack config. [2025-05-09 19:10:14] info: zh:ember: ======== Ember Adapter Starting ======== [2025-05-09 19:10:14] info: zh:ember:ezsp: ======== EZSP starting ======== [2025-05-09 19:10:14] info: zh:ember:uart:ash: ======== ASH Adapter reset ======== [2025-05-09 19:10:14] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control. [2025-05-09 19:10:14] info: zh:ember:uart:ash: Serial port opened [2025-05-09 19:10:14] info: zh:ember:uart:ash: ======== ASH starting ======== [2025-05-09 19:10:15] info: zh:ember:uart:ash: ======== ASH connected ======== [2025-05-09 19:10:15] info: zh:ember:uart:ash: ======== ASH started ======== [2025-05-09 19:10:15] info: zh:ember:ezsp: ======== EZSP started ======== [2025-05-09 19:10:15] error: z2m: Error while starting zigbee-herdsman [2025-05-09 19:10:15] error: z2m: Failed to start zigbee-herdsman [2025-05-09 19:10:15] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions [2025-05-09 19:10:15] error: z2m: Exiting... [2025-05-09 19:10:15] error: z2m: Error: Adapter EZSP protocol version (8) is not supported by Host [13-16]. at EmberAdapter.emberVersion (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1417:19) at EmberAdapter.initEzsp (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:670:9) at EmberAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1548:24) at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29) at Zigbee.start (/app/lib/zigbee.ts:70:27) at Controller.start (/app/lib/controller.ts:104:13) at start (/app/index.js:149:5) [19:10:17] INFO: Preparing to start... [19:10:17] INFO: Socat not enabled [19:10:17] INFO: Starting Zigbee2MQTT... Starting Zigbee2MQTT without watchdog. [2025-05-09 19:10:22] info: z2m: Logging to console, file (filename: log.log) [2025-05-09 19:10:22] info: z2m: Starting Zigbee2MQTT version 2.3.0 (commit #unknown) [2025-05-09 19:10:22] info: z2m: Starting zigbee-herdsman (4.0.0) [2025-05-09 19:10:23] info: zh:ember: Using default stack config. [2025-05-09 19:10:23] info: zh:ember: ======== Ember Adapter Starting ======== [2025-05-09 19:10:23] info: zh:ember:ezsp: ======== EZSP starting ======== [2025-05-09 19:10:23] info: zh:ember:uart:ash: ======== ASH Adapter reset ======== [2025-05-09 19:10:23] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control. [2025-05-09 19:10:23] info: zh:ember:uart:ash: Serial port opened [2025-05-09 19:10:23] info: zh:ember:uart:ash: ======== ASH starting ======== [2025-05-09 19:10:24] info: zh:ember:uart:ash: ======== ASH connected ======== [2025-05-09 19:10:24] info: zh:ember:uart:ash: ======== ASH started ======== [2025-05-09 19:10:24] info: zh:ember:ezsp: ======== EZSP started ======== [2025-05-09 19:10:24] error: z2m: Error while starting zigbee-herdsman [2025-05-09 19:10:24] error: z2m: Failed to start zigbee-herdsman [2025-05-09 19:10:24] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions [2025-05-09 19:10:24] error: z2m: Exiting... [2025-05-09 19:10:24] error: z2m: Error: Adapter EZSP protocol version (8) is not supported by Host [13-16]. at EmberAdapter.emberVersion (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1417:19) at EmberAdapter.initEzsp (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:670:9) at EmberAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1548:24) at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29) at Zigbee.start (/app/lib/zigbee.ts:70:27) at Controller.start (/app/lib/controller.ts:104:13) at start (/app/index.js:149:5) J'ai refait l'installation 2 fois (après avoir rechargé un OS vierge), j'ai même essayé de changer de port, le dongle Zigbee, sans pouvoir trouver une solution. D'après certains avis lus çà et là, il faudrait que je passe maintenant par une étape "reflasher le firmware du dongle", mais là franchement, j'hésite car la box HA et le Dongle Sonoff sont neufs !
  10. Bonjour à tous, Je cherche à automatiser la gestion de ma pompe de piscine ainsi que l’éclairage du bassin via Home Assistant, et je me pose plusieurs questions avant de me lancer. Mon installation actuelle :Tout semble centralisé dans un tableau électrique dédié à la piscine, avec : Une horloge mécanique sur le boîtier du haut, que j’aimerais conserver comme système de secours en cas de panne de Home Assistant. Un boîtier en bas avec des interrupteurs pour la pompe à chaleur, proposant plusieurs modes : manuel, auto (via horloge), ou inactif. Un autre interrupteur pour la lumière de la piscine. Mes questions :Peut-on connecter tout cela à Home Assistant sans tout casser ? Avez-vous déjà domotisé une installation similaire (pompe + lumière piscine) ? Je suis un peu novice dans la domotisation des tableaux électriques, donc je suis preneur d’instructions détaillées. Quels modules Zigbee, Z-Wave ou Wi-Fi recommandez-vous pour ce type de projet (relais, contacteurs, interrupteurs connectés…) ? L’objectif est de pouvoir piloter la pompe et la lumière depuis mon téléphone, tout en gardant un mode secours via l’horloge actuelle. Merci d’avance pour vos retours, vos schémas si vous en avez, et vos conseils sur le meilleur matériel pour domotiser une piscine !
  11. Recherche contrôleur pH et chlore Zigbee pour piscine (équipement HS) et aide pour tests Bonjour à tous, Je me tourne vers vous car j’ai besoin d’aide pour finaliser mon projet de gestion de piscine connectée. Mon contrôleur actuel de pH et de chlore est HS (il a pris l’eau 😞), et je recherche un nouveau modèle compatible Zigbee pour remplacer mon ancien équipement. Si quelqu’un a un bon plan ou un contrôleur d’occasion à vendre, je suis preneur ! Pour donner un peu de contexte, j’ai développé une intégration personnalisée appelée Piscinexa sous Home Assistant, qui gère plusieurs capteurs pour ma piscine : température, pH, chlore, volume d’eau, temps de filtration, etc. Voici un extrait de mon code pour illustrer mon setup : Capteur pH Actuel (PiscinexaPhSensor) : récupère la valeur du pH via un capteur externe ou un input_number. Capteur Chlore Actuel (PiscinexaChloreSensor) : récupère la valeur du chlore actuel de la même manière. Capteur Chlore Différence (PiscinexaChloreDifferenceSensor) : calcule la différence entre le chlore actuel et le chlore cible. Capteur Chlore à Ajouter (PiscinexaChloreAjouterSensor) : initialement, il calculait la dose de chlore à ajouter (en fonction du volume, de la température, et du type de traitement – liquide, pastille lente, ou poudre), mais j’ai retiré cette logique du capteur pour la déplacer ailleurs (actuellement, ce capteur est désactivé). Mon objectif est de finaliser ce projet en intégrant un nouveau contrôleur Zigbee capable de mesurer le pH et le chlore en temps réel. Idéalement, je voudrais un appareil comme le Yago 7-en-1 (Zigbee Tuya), qui mesure pH, chlore libre, ORP, salinité, etc., mais je suis ouvert à d’autres suggestions si vous avez des retours d’expérience. En parallèle, je cherche aussi des personnes qui auraient un peu de temps pour m’aider à tester mon code et à l’améliorer. Par exemple, je voudrais intégrer un service ou une automatisation pour gérer le calcul du chlore à ajouter (que j’ai retiré de sensor.py), mais je ne suis pas sûr de la meilleure approche. Si quelqu’un est intéressé, je peux partager plus de détails sur mon code et mon setup ! Merci d’avance pour votre aide, vos suggestions, ou vos bons plans pour un contrôleur Zigbee. 😊 Cordialement,
  12. Zatoufly a posté un message dans un sujet dans Intégrations et Add-ons
  13. nico8383 a posté un message dans un sujet dans Installation et Configuration
  14. Je reviens vers vous pour vous indiquer ma solution. Oui il se trouve qu'il y en a une et je l'ai déjà abordé en fait. Le changement de canal est la clé de la résolution de ce problème, mais il me manquait une information. Il est possible de changer facilement de canal avec la configuration de Zigbee2MQTT mais même si lui le fait correctement, ce n'est pas le cas de certains coordinateurs. Mon coordinateur qui est un SONOFF Zigbee 3.0 Plus P, et j'ai découvert le problème que lorsque j'ai décidé de réinitialiser mes clés de chiffrement. Au démarrage de Zigbee2MQTT, il y avait une erreur qui me disait que le coordinateur n'acceptait pas la modification, il suffit de l'ouvrir et de le connecter tout en restant appuyé sur le bouton BOOT. Mais avant d'en arrivé là, une chose me chiffonne dans le message de log. Il se trouve qu'il y a d'indiqué le canal que Zigbee2MQTT utilise ... Mais aussi celui du coordinateur. Et devinez quoi, ce n'était pas le nouveau mais bien le premier (celui que j'utilisais au début, le canal 11). Du coup le fait d'avoir réinitialisé le coordinateur a tout réglé, et je suis maintenant sur le canal 15. Ouf, j'y ai juste passé toute la journée 🫠
  15. La semaine dernière
  16. Didierhlg a posté un message dans un sujet dans Confort et Ambiance
  17. Description du projet PiscinexaGitHubGitHub - XAV59213/piscinexa: gestion de piscinegestion de piscine. Contribute to XAV59213/piscinexa development by creating an account on GitHub.GitHub : XAV59213/piscinexa Nom de l'intégration : Piscinexa Plateforme : Home Assistant Langage : Python Objectif : L'intégration Piscinexa est une solution personnalisée pour la gestion et la surveillance des piscines via Home Assistant. Elle permet de suivre et de gérer les paramètres clés d'une piscine, tels que le volume d'eau, la température, le pH, le niveau de chlore, le temps de filtration, et la consommation de puissance. L'intégration fournit également des recommandations pour ajuster les niveaux de pH et de chlore, ainsi qu'un tableau de bord personnalisé pour visualiser et contrôler ces paramètres. Fonctionnalités principales : Surveillance des capteurs : Capteurs pour le volume d'eau (calculé en fonction des dimensions de la piscine). Capteur de température (via un capteur externe ou une saisie manuelle). Capteur de pH (via un capteur externe ou une saisie manuelle). Capteur de chlore (via un capteur externe ou une saisie manuelle). Capteur de temps de filtration (calculé en fonction de la température). Capteur de consommation de puissance (via un capteur externe). Capteur d'état global de la piscine (indique si la baignade est autorisée en fonction des paramètres). Recommandations d'ajustement : Calcul de la quantité de pH+ ou pH- à ajouter pour atteindre une valeur cible. Calcul de la quantité de chlore à ajouter (en fonction du type de traitement : liquide, granulés, ou pastilles). Contrôles et saisie manuelle : Boutons pour tester les calculs ou réinitialiser les valeurs. Entrées manuelles pour le pH et le chlore actuels via des input_number. Sélection du type de traitement chimique via des input_select (par exemple, liquide, granulés, pastilles). Tableau de bord personnalisé : Fichiers YAML (piscine_dashboard_custom_component.yaml et piscine_dashboard_multi.yaml) pour afficher les capteurs, les recommandations, et les contrôles dans une interface utilisateur claire. Support pour une ou plusieurs piscines (par exemple, piscine et spa). Traduction : Support multilingue via un fichier de traduction (translations/fr.json) pour afficher les noms des entités et les messages en français (par exemple, "Température Eau", "Chlore", "pH"). Configuration de la vue Piscine :type: sections max_columns: 4 title: Piscine path: pisine sections: - type: grid cards: - type: heading heading: Gestion de piscine heading_style: title badges: - type: entity entity: sensor.piscine_chlore_difference - type: vertical-stack cards: - type: entities title: Informations principales Clhore show_header_toggle: false entities: - entity: sensor.piscine_chlore_cible icon: mdi:pool - entity: sensor.piscine_chlore_difference icon: mdi:clock state_color: true - type: entities title: Qualité de l'eau Clhore show_header_toggle: false entities: - entity: sensor.piscine_chlore_actuel name: Chlore actuel icon: mdi:water-check - entity: sensor.piscine_chlore_a_ajouter name: Chlore à ajouter icon: mdi:bottle-tonic-plus - entity: sensor.piscine_consommation_puissance - type: history-graph title: Historique Chlore (48h) hours_to_show: 48 refresh_interval: 300 entities: - entity: sensor.piscine_chlore_actuel name: Chlore logarithmic_scale: true - type: history-graph title: " Historique pH et Chlore (48h)" hours_to_show: 48 refresh_interval: 300 entities: - entity: sensor.piscine_ph_actuel - entity: sensor.piscine_chlore_actuel logarithmic_scale: true - type: vertical-stack cards: - type: entities title: Informations principales pH show_header_toggle: false entities: - entity: sensor.piscine_ph_cible icon: mdi:clock - entity: sensor.piscine_ph_actuel name: Piscine pH Différence - type: entities title: Qualité de l'eau pH show_header_toggle: false entities: - entity: sensor.piscine_ph_actuel name: pH actuel icon: mdi:water-ph - entity: sensor.piscine_ph_a_ajouter_2 - entity: sensor.piscine_ph_a_ajouter_2 - type: history-graph title: Historique Ph (48h) hours_to_show: 48 refresh_interval: 300 entities: - entity: sensor.piscine_temperature name: °C logarithmic_scale: true - type: history-graph title: Historique Température (48h) hours_to_show: 48 refresh_interval: 300 entities: - entity: sensor.piscine_temperature logarithmic_scale: true - type: vertical-stack cards: - type: entities title: " Contrôle Qualité Piscine " show_header_toggle: false entities: - entity: sensor.piscine_volume_d_eau name: Volume d'eau icon: mdi:pool - entity: sensor.piscine_temps_de_filtration_recommande name: Temps de filtration recommandé icon: mdi:clock - entity: sensor.piscine_temps_de_filtration_effectue - type: entities title: Qualité de l'eau show_header_toggle: false entities: - entity: sensor.piscine_ph_actuel name: pH actuel icon: mdi:water-ph - entity: sensor.piscine_chlore_actuel name: Chlore actuel icon: mdi:water-check - type: entities title: Consommation show_header_toggle: false entities: - entity: sensor.piscine_consommation_puissance name: Consommation de puissance icon: mdi:flash - type: entities title: Journal des actions show_header_toggle: false entities: - entity: sensor.piscine_journal name: Journal icon: mdi:notebook - type: horizontal-stack cards: - show_name: true show_icon: true type: button entity: button.tester name: Tester les calculs icon: mdi:calculator tap_action: action: call-service service: piscinexa.test_calcul service_data: name: piscine - show_name: true show_icon: true type: button entity: button.reinitialiser name: Réinitialiser les valeurs icon: mdi:refresh tap_action: action: call-service service: piscinexa.reset_valeurs service_data: name: piscine - type: history-graph title: Calendrier Pompage hours_to_show: 48 refresh_interval: 300 entities: - entity: calendar.pompage_piscine logarithmic_scale: true column_span: 3 badges: - type: entity show_name: false show_state: true show_icon: true entity: sensor.piscine_consommation_puissance - type: entity show_name: false show_state: true show_icon: true entity: sensor.piscine_etat_de_la_piscine - type: entity show_name: false show_state: true show_icon: true entity: calendar.pompage_piscine icon: mdi:pool-thermometer cards: []
  18. Bidibulle a rejoint la communauté
  19. Bonjour ici 😊 C'est la deuxième fois que ça m'arrive depuis que j'ai Zigbee, vous allez comprendre (ou dites moi si je me trompe). Dans la matinée je remarque que mon plafonnier ne s'allume plus (ça pourrait provenir de plein de choses puisque je bidouille), mais je me suis aperçu aussi vite que plus rien ne fonctionnait dans la maison! Tout s'affiche comme "Non disponible" sur Zigbee2MQTT et un redémarrage (et un rebranchement du dongle) ne donne aucune amélioration contrairement à la première fois que ça s'est produit. Alors je me précipite sur Portainer pour consulter les logs et surprise... De l'orange "warning" et du rouge "error" de partout! Après avoir demandé à notre ami à tous Chat GéPéTou, il s'avère que le WiFi est congestionné 🧐 Exemple de logs en question: MAC channel access failure [2025-05-08 18:26:25] warning: z2m: Failed to ping 'Salon: Spot 3' (attempt 1/1, ZCL command 0x28dba7fffee02848/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))) No network route [2025-05-08 18:26:47] error: zh:controller:device: Read response to 0xa4c13830b31de5f7 failed (ZCL command 0xa4c13830b31de5f7/1 genTime.readRsp({"localTime":800042958}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":1,"reservedBits":0,"transactionSequenceNumber":194,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))) J'hallucine mais pense à vérifier l'occupation via FreeboxOS et en comparant les canaux Zigbee/WiFi il y a bien un gros soucis (que je ne peux apparemment pas régler). Étant sur le canal 11 côté Zigbee il s'avère que ça correspond au canal 1 du WiFi, comme vous pouvez le voir, c'est loin d'être optimal 😡 Solution vous me direz, changer de canal Zigbee, et bah oui mais non... J'ai essayé le 15, le 20, ainsi que le 25, mais rien. Quand je dis rien, c'est qu'il n'y a aucun appareil qui veut s'appairer. Même en réinitialisant tout Zigbee2MQTT (sauf mes clés), la liste reste vide. Donc je suis bloqué avec toute ma domotique qui est en carafe. Est-ce que vous avez une idée qui pourrait me sortir de ce bourbier ? 🥺
  20. Arubinu a posté un message dans un sujet dans Matériel et Marques
    Salut, pour moi ta seule option est de passer ton installation LED sur un contrôleur (l'alim en soit) Zigbee. Celui-ci gèrera notamment l'intensité lumineuse. Ensuite pour le contrôler tu peux ajouter un variateur connecté (tant qu'à faire en Zigbee). Personnellement j'utilise les interrupteurs IKEA STYRBAR, qui est connecté à Home Assistant via Zigbee2MQTT. Mais tu peux tout à fait le relier en direct à ton contrôleur, il me semble
  21. Arubinu a posté un message dans un sujet dans Sonoff
    Salut, ZHA fonctionne actuellement? Ton coordinateur ne peut être utilisé que par un seul programme, donc il te faudra arrêter ZHA pour pouvoir l'utiliser avec Z2M.
  22. Pour le soucis de production, je suppose que tu as passé ton Linky en mode classique et non historique? Sans ça déjà le compteur ne prendra pas en charge la production. Si c'est déjà le cas, il y a une option dans le Lixee pour dire que tu fais de la production.
  23. Charpy a posté un message dans un sujet dans Présentations des Membres
    Bonjour, je suis Charpy. Je me passionne pour la domotique depuis un certain temps. J'ai débuté sur Jeedom, puis suis passé à Home Assistant. Actuellement, mon installation Home Assistant tourne sur Proxmox. J’utilise le protocole RTS pour contrôler les volets, et du ZigBee pour gérer l’éclairage, le chauffage, l’alarme, la porte de garage, la production d’énergie via des panneaux solaires, la station météo, ainsi que l’arrosage automatique. Aujourd’hui, je suis en plein casse-tête pour créer un système domotique vraiment au top !
  24. Charpy a rejoint la communauté
  25. Effectivement c'est encore mieux que ce que je demandais car, en plus de la mise en évidence par le bandeau vert de l'indication "Résolu", la possibilité d'aller directement à la réponse est géniale ! Merci Jack !
  26. Patoc a posté un message dans un sujet dans Box & Matériel
    Merci beaucoup pour ces infos !
  27. BièreNard a posté un message dans un sujet dans Confort et Ambiance
    Oups, je ne voyais pas bien la configuration ! Si j'ai bien compris : il n'y a pas de bouton de commande variateur sur le mur de chaque pièce, mais seulement une télécommande commune permettant de faire varier individuellement l'intensité lumineuse des 3 points d'éclairage (je suppose qu'il y a un donc module DIO installé dans chaque lampe à commander). Dans ce cas en effet, il n'est pas facile de trouver une solution équivalente en Zigbee (car les télécommandes fonctionnent en général avec des modules en RF ou Wifi). La seule solution que je vois, serait de remplacer les modules DIO des lampes par des modules variateur Zigbee (un exemple ici) et de remplacer la télécommande DIO par le téléphone avec l'appli HA. Bon courage @Didierhlg
  28. PhG a commencé à suivre Module dimmable
  29. Hello, C'est plus un format vlog "regardé, je test de faire ça chez moi et je vous montre comment je procède" que tutoriel. Moi qui pensais que ça n'intéressait pas grand monde, bien au contraire ! Content que ça en motive plus d'un. Avec plaisir ;)
  30. Paul a commencé à suivre Module dimmable
  31. Paul a posté un message dans un sujet dans Matériel et Marques
    Bonjour, J'ai une installation de LED avec variateur dans un meuble. Les LED sont commandés par un interrupteur manuel mais je souhaite aussi les commander avec home assistant. Donc je veux installer un module derrière l'interrupteur mais j'ai besoin qu'il soit dimmable et avec le neutre. De plus, j'ai configuré le protocole Zigbee MQTT sur ma box home assistant green. Auriez-vous des suggestions de module? Merci
  32. Paul a rejoint la communauté
  33. Bonjour Nico8383, Ceci est du au fait qu'un script, une intégration, ou un appareil local essaie d’accéder à votre instance Home Assistant depuis l’adresse locale 127.0.0.1 (donc depuis la même machine) mais sans les bonnes informations d’authentification. Vous pouvez vérifier les logs pour voir de quel instance il s'agit. Je demeure disponible si vous avez d'autres questions. Merci!
  34. nadom_technologies a rejoint la communauté
  35. ✅ Vous l’avez demandé… on l’a fait !Les balises Spoiler sont désormais disponibles sur ForumDomotique.com Vous étiez plusieurs à le demander, notamment pour cacher des captures d’écran, de longs logs, ou des surprises dans vos messages… c’est maintenant possible ! 💬 Utilisez la balise pour masquer une partie de votre message, qui ne s’affichera qu’au clic. Pratique pour alléger la lecture et ne pas tout dévoiler d’un coup. Elle est disponible dans le menu "+" de l'éditeur de messages. Exemple : Spoiler Le contenu est révélé à la demande ! Merci à tous pour vos retours constructifs, continuez à nous dire ce qu’il vous manque, on bosse dessus pour faire avancer la communauté 💪 !
