phil40990 a rejoint la communauté
bipbip33 a rejoint la communauté
Vpon a rejoint la communauté
Marcon a rejoint la communauté
Didier F a rejoint la communauté
ARNAUD Régis a rejoint la communauté
Max974 a rejoint la communauté
Présentation rapide !
Looking to obtain official documents online without the stress? You’re in the right place. We specialize in helping individuals and businesses access legitimate, government-issued documents quickly, securely, and through the proper legal channels https://realdocsexpress.com From passports and ID cards to business, drivers licenses and academic records, our service is designed to simplify the entire process. No confusing paperwork, no unnecessary delays—just clear guidance and reliable support from start to finish. Website: https://realdocsexpress.com Obtain 100% valid passport Buy a ID card fully Verified BUY Passport Online Drivers License Without attending the Exam Certificate is an important step in your education Buy an International PASSPORT Buy DRIVERS LICENSE without Exam Buy Residence permit Buy Real and fake Certificate Online Buy ID Card Website: https://realdocsexpress.com Website: https://realdocsexpress.com Why Choose Us? ✔️ Simple Online Process Apply for your documents from the comfort of your home. Our easy-to-use platform walks you through each step, ensuring your application is complete and accurate. ✔️ Trusted & Compliant We work only with authorized agencies and official systems, ensuring that every document you receive is genuine, verifiable, and legally recognized. ✔️ Fast Processing Times We help minimize delays by reviewing your application carefully before submission, so you can get your passport, ID, business registration, or academic certificate as quickly as possible. ✔️ Expert Support टीम Our dedicated support team is always ready to assist with questions, updates, or guidance—making your experience smooth and stress-free. Website: https://realdocsexpress.com Website: https://realdocsexpress.com Our Document Services Include: Passport Application & Renewal Services National ID Card Processing Assistance Business License & Company Registration Support Academic Records & Certificate Requests Official Document Corrections & Updates Secure, Reliable & Customer-Focused Your privacy and security are our top priorities. We use secure systems to protect your information and ensure every transaction is handled with care and confidentiality. Website: https://realdocsexpress.com Website: https://realdocsexpress.com
Welcome to Chemshome.
XAV59213 a commencé à suivre 🏠 Freebox Homexa passe en 28.8.64 !
remi3 a commencé à suivre Utilisation de modules fil pilote et d'un delesteur
Michel 71590 a commencé à suivre Comment relier ma pompe a chaleur et mes panneaux photovoltaïques ?
Bonjour à tous, Je sollicite votre aide pour affiner la configuration de mon installation dans mon couloir. J'ai un comportement gênant avec mon détecteur de mouvement : si je reste devant, la lumière s'éteint au bout de la minuterie sans se relancer, et il y a une latence avant qu'elle ne se rallume. 🛠️ Ma configuration matérielle : Circuit : Ancien va-et-vient câblé sans Neutre (Phase et retour lampe dans deux boîtes distinctes, navettes utilisées pour centraliser). Module : 1x Shelly Dimmer Gen4 (installé dans la boîte contenant le retour lampe). Commandes physiques : 2x Boutons poussoirs raccordés en parallèle sur l'entrée SW du Shelly (configuré en mode Button). Éclairage : 2x Ampoules LED dimmables standards + 1x Shelly Bypass installé en parallèle sur l'une des appliques pour stabiliser l'alimentation du module. Détection : 1x Détecteur Shelly BLU Motion (Bluetooth), appairé directement au Shelly Dimmer Gen4 qui lui sert de passerelle BLE. ⚙️ Ma configuration logicielle (Application Shelly Smart Control) : J'ai créé deux scènes distinctes basées sur des plages horaires pour gérer l'intensité (Mode jour à 100% / Mode nuit à 20%) : Condition (QUAND) : Shelly BLU Motion ➡️ Mouvement détecté (avec contrainte horaire). Action 1 (FAIRE) : Shelly Dimmer Gen4 ➡️ Allumer (à 100% ou 20%). Action 2 (FAIRE) : Shelly Dimmer Gen4 ➡️ Éteindre ➡️ avec une temporisation (délai) de 60 secondes. 🧪 Mes tests déjà effectués : L'Auto-Off du Gen4 : J'ai essayé d'enlever l'action d'extinction de ma scène pour utiliser à la place la fonction native "Auto-Off" (minuterie interne) directement dans les réglages du module Shelly Dimmer Gen4. Le problème reste identique. Options de la Scène : Dans la condition de déclenchement liée au BLU Motion, j'ai testé les modes "Once" (Une fois) et "On any change" (À chaque changement). Aucun des deux ne résout le souci. Hypothèse : Je suspecte fortement un impact ou un conflit lié au "Blind Time" (temps mort) interne du Shelly BLU Motion. ❓ Le problème : Lorsque j'entre dans le couloir, la détection est instantanée et la lumière s'allume bien. En revanche, si je reste actif devant le détecteur, la minuterie de 60 secondes ne se remet pas à zéro. La lumière finit par s'éteindre malgré ma présence. Pire, une fois éteinte, je dois attendre plusieurs secondes ou m'agiter à nouveau devant pour que le détecteur daigne renvoyer un ordre d'allumage. Avez-vous une astuce dans la logique des scènes Shelly ou un réglage spécifique sur le combo BLU Motion (sensibilité, blind time) / Dimmer pour que le mouvement continu maintienne la lumière allumée (prolongation de la minuterie) sans coupure ? Merci d'avance pour vos lumières !
yac83 a commencé à suivre abigaëlle, technicienne réseau et maison sous home assistant
Ok ☹️
Module radio dimmable
Hello ! Je ne sais pas combien ici utilisent encore Portainer pour gérer leurs conteneurs Docker, mais il y a du changement qui se prépare du côté du projet. Portainer 3.0 prend désormais clairement la direction de Kubernetes, tandis que la Community Edition que nous connaissons restera sur la branche 2.x. Pas de panique pour autant : Portainer CE ne s'arrête pas du jour au lendemain. La branche 2.x continue d'être maintenue et il n'y a donc aucune urgence à migrer une installation qui fonctionne correctement. Mais pour nos usages domotiques, la nouvelle orientation pose quand même question. Beaucoup d'entre nous utilisent Docker sur un Raspberry Pi, un NAS ou un mini PC pour faire tourner Home Assistant, Zigbee2MQTT, Mosquitto, Node-RED, Frigate, ESPHome, Grafana, AdGuard Home, etc. Dans ce contexte, passer à Kubernetes serait souvent sortir l'artillerie lourde pour pas grand-chose 😅 J'en ai donc profité pour regarder sérieusement les alternatives actuelles à Portainer. Il y en a quatre qui m'ont particulièrement intéressé : Arcane, qui ressemble probablement le plus à un remplaçant moderne de Portainer ; Dockge, beaucoup plus simple et vraiment centré sur Docker Compose ; Komodo, très intéressant lorsqu'on commence à administrer plusieurs serveurs ; et Dockhand, particulièrement complet, notamment sur les fonctions de sécurité. J'ai regroupé mes recherches et les différences entre ces solutions dans un article : Maison et DomotiquePortainer change de cap : faut-il déjà chercher une alter...Portainer 3.0 mise sur Kubernetes et la CE reste en 2.x. Faut-il changer ? Arcane, Dockge, Komodo et Dockhand pour gérer Docker et Home Assistant. Pour ma part, Arcane est celui qui me donne le plus envie d'être testé sur une vraie installation domotique. Il semble assez proche de l'expérience Portainer tout en étant très actif actuellement. Mais je serais surtout intéressé par vos retours : vous utilisez toujours Portainer ? Avez-vous déjà essayé Arcane, Dockge, Komodo, Dockhand ou une autre solution ? Et surtout, pour ceux qui ont migré : est-ce que vous y avez réellement gagné quelque chose à l'usage ?
