Igbinedion University Okada POST UTME 2026/2027 ADMISSION FORM Is Out Call ☎️ (0)9165949470 or 09165949470 to Apply The Sales of Jupeb/Post Utme form, Pre-degree Form, Ijmb Form, Jupeb Form, Master Form, Inter-school Transfer Form for more Information On
Igbinedion University Okada POST UTME 2026/2027 ADMISSION FORM Is Out Call ☎️ (0)9165949470 or 09165949470 to Apply The Sales of Jupeb/Post Utme form, Pre-degree Form, Ijmb Form, Jupeb Form, Master Form, Inter-school Transfer Form for more Information On How to apply and admission Assistance. Forms into other programmes are also now available. Contact 09165949470 the school Admin - 09165949470 for more inquiries. The School Authority requires all candidates applying for admission into any of its courses to possess Five (5) O’ Level Credit Level Passes at not more than two (2) sittings to include English Language and Mathematics and three (3) other subjects relevant to course.
Babcock University,Ilishan-Remo POST UTME 2026/2027 ADMISSION FORM Is Out Call ☎️ (0)9165949470 or 09165949470 to Apply The Sales of Jupeb/Post Utme form, Pre-degree Form, Ijmb Form, Jupeb Form, Master Form, Inter-school Transfer Form for more Information
Babcock University,Ilishan-Remo POST UTME 2026/2027 ADMISSION FORM Is Out Call ☎️ (0)9165949470 or 09165949470 to Apply The Sales of Jupeb/Post Utme form, Pre-degree Form, Ijmb Form, Jupeb Form, Master Form, Inter-school Transfer Form for more Information On How to apply and admission Assistance. Forms into other programmes are also now available. Contact 09165949470 the school Admin - 09165949470 for more inquiries. The School Authority requires all candidates applying for admission into any of its courses to possess Five (5) O’ Level Credit Level Passes at not more than two (2) sittings to include English Language and Mathematics and three (3) other subjects relevant to course.
Madonna University, Okija POST UTME 2026/2027 ADMISSION FORM Is Out Call ☎️ (0)9165949470 or 09165949470 to Apply The Sales of Jupeb/Post Utme form, Pre-degree Form, Ijmb Form, Jupeb Form, Master Form, Inter-school Transfer Form for more Information On Ho
Madonna University, Okija POST UTME 2026/2027 ADMISSION FORM Is Out Call ☎️ (0)9165949470 or 09165949470 to Apply The Sales of Jupeb/Post Utme form, Pre-degree Form, Ijmb Form, Jupeb Form, Master Form, Inter-school Transfer Form for more Information On How to apply and admission Assistance. Forms into other programmes are also now available. Contact 09165949470 the school Admin - 09165949470 for more inquiries. The School Authority requires all candidates applying for admission into any of its courses to possess Five (5) O’ Level Credit Level Passes at not more than two (2) sittings to include English Language and Mathematics and three (3) other subjects relevant to course.
information75 a rejoint la communauté
BCS24 a rejoint la communauté
Bonjour, Un répéteur Wi‑Fi installé à l’intérieur fonctionne rarement correctement jusqu’au fond d’un grand jardin, surtout lorsque le signal doit traverser plusieurs murs. La solution la plus stable serait plutôt un point d’accès Wi‑Fi extérieur, résistant aux intempéries, placé en hauteur sur la façade orientée vers le jardin. Si la distance est importante, l’idéal est de relier ce point d’accès à la box par câble Ethernet. À défaut, un système Wi‑Fi Mesh avec une borne proche d’une fenêtre peut améliorer la couverture, mais ses performances dépendront toujours des obstacles. Le CPL peut aussi être envisagé si l’installation électrique du local extérieur est compatible. Avant tout achat, je vérifierais également si le robot a réellement besoin d’une connexion Wi‑Fi permanente pendant la tonte. Certains modèles utilisent le Wi‑Fi principalement pour les mises à jour, la configuration et la consultation à distance, puis travaillent de manière autonome grâce au RTK, au LiDAR ou à leur cartographie enregistrée. Quelle est approximativement la distance entre la maison et le fond du jardin ? Et le robot doit-il contourner un bâtiment ou des murs épais ? Bonjour, Un répéteur Wi‑Fi installé à l’intérieur fonctionne rarement correctement jusqu’au fond d’un grand jardin, surtout lorsque le signal doit traverser plusieurs murs. La solution la plus stable serait plutôt un point d’accès Wi‑Fi extérieur, résistant aux intempéries, placé en hauteur sur la façade orientée vers le jardin. Si la distance est importante, l’idéal est de relier ce point d’accès à la box par câble Ethernet. À défaut, un système Wi‑Fi Mesh avec une borne proche d’une fenêtre peut améliorer la couverture, mais ses performances dépendront toujours des obstacles. Le CPL peut aussi être envisagé si l’installation électrique du local extérieur est compatible. Avant tout achat, je vérifierais également si le robot a réellement besoin d’une connexion Wi‑Fi permanente pendant la tonte. Certains modèles utilisent le Wi‑Fi principalement pour les mises à jour, la configuration et la consultation à distance, puis travaillent de manière autonome grâce au RTK, au LiDAR ou à leur cartographie enregistrée. Quelle est approximativement la distance entre la maison et le fond du jardin ? Et le robot doit-il contourner un bâtiment ou des murs épais ?
RobotExterieur a rejoint la communauté
chitou a rejoint la communauté
Présentation ManGhost
Salut à tous, Je reviens de l’IFA de Berlin, où je suis notamment passé sur le stand Aqara. Et cette année, pas de nouveau petit capteur vedette : la marque s’attaque franchement à l’éclairage connecté, aussi bien à l’intérieur qu’à l’extérieur. Cinq nouveautés étaient présentées : la Floor Lamp T1, une lampe verticale avec 18 zones lumineuses indépendantes, le LED Strip T2 avec ses 108 LED/m, le Downlight T2 pour les spots encastrés, ainsi que les Outdoor String Lights H1 et Permanent Outdoor Lights H1 pour le jardin et les façades. Le choix technique est plutôt intéressant pour nous autres amateurs de domotique : tous ces éclairages proposent Thread ET Zigbee. On peut donc partir sur Thread/Matter pour les intégrer à Home Assistant, Apple Home, Google Home, etc., ou rester en Zigbee pour profiter des fonctions et automatisations plus poussées d’Aqara Home. Sur le stand, Aqara avait justement recréé une véritable pièce à vivre pour montrer l’interaction entre les éclairages, les capteurs, les interrupteurs et le Cube T1 Pro. C’est beaucoup plus parlant que quelques ampoules alignées sur une étagère : on voit bien que l’objectif est désormais de faire varier automatiquement toute l’ambiance d’une pièce selon la présence ou le scénario en cours. J’ai regroupé les caractéristiques des cinq produits et mes impressions après les avoir vus fonctionner à Berlin dans l’article : Maison et DomotiqueIFA 2026 : Aqara étend son écosystème avec des éclairages...À l'IFA 2026 de Berlin, Aqara dévoile cinq nouveaux éclairages connectés Thread, Zigbee et Matter pour équiper la maison et le jardin. Personnellement, le double choix Thread/Zigbee me paraît être l’un des points les plus intéressants de cette nouvelle gamme. Et les Permanent Outdoor Lights H1 me font déjà imaginer quelques scénarios sympas autour de la maison 😅 Curieux d’avoir votre avis : parmi ces nouveautés, laquelle vous tenterait le plus ? Et pour ce type d’éclairage, vous partiriez plutôt sur Matter/Thread ou Zigbee ?
Salut à tous, Je suis actuellement à Berlin pour couvrir l’IFA et j’ai assisté à la conférence de BLUETTI. J’avais déjà découvert la nouvelle gamme Balco lors d’une présentation à Paris, et j’utilise depuis quelque temps le Balco 260 + BC260 chez moi pour stocker mon surplus photovoltaïque. À l’IFA, la stratégie de BLUETTI devient beaucoup plus claire : la marque ne veut plus simplement vendre des power stations, mais construire un véritable écosystème énergétique pour la maison. Parmi les nouveautés intéressantes : 🔋 Balco 500 : 5 kWh de stockage, jusqu’à 4,6 kW de PV et 3,68 kW en sortie. On commence sérieusement à s’éloigner du simple kit solaire de balcon ! 🤖 BlueBot : une IA qui analyse production solaire, consommation, météo, tarifs électriques et état des batteries pour optimiser automatiquement l’énergie de la maison. 🔌 EnergyFlex / Balco Transfer : une idée que je trouve particulièrement sympa puisqu’elle permet d’utiliser une power station comme batterie domestique, puis de la débrancher pour l’emmener en voyage. 🏠 BLUETTI Space : jusqu’à six unités peuvent travailler ensemble pour constituer un stockage distribué dans la maison. 🏗️ Pioneer 5000 E-Generator : beaucoup plus orienté pro, avec 5 kW continus et surtout 18 kW en pointe pour alimenter des machines de chantier. GPS et 4G sont même prévus sur certaines versions. 🎒 Elite Mini : trois nouvelles power stations plus compactes et légères. Ce qui m’intéresse surtout dans cette évolution, c’est la partie HEMS. Les batteries savent maintenant très bien stocker des kWh ; le prochain enjeu est de décider intelligemment quand les charger et les décharger. Ayant justement testé le Balco 260 sur ma propre installation, j’ai essayé dans l’article de faire le lien entre ce qui existe déjà et la direction prise par BLUETTI avec le Balco 500 et BlueBot. 👉 Article complet : Maison et DomotiqueBLUETTI à l’IFA 2026 : Balco 500, BlueBot, Pioneer 5000…...À l’IFA 2026, BLUETTI dévoile le Balco 500, BlueBot, le Pioneer 5000 et sa nouvelle vision d’un écosystème énergétique intelligent. Je serais curieux d’avoir votre avis, notamment sur BlueBot : est-ce que vous seriez prêts à laisser une IA gérer automatiquement votre batterie en fonction de la météo, des tarifs et de vos habitudes ? Ou vous préférez garder la main avec vos propres automatisations Home Assistant / Jeedom ? 😉
présentation sommaire
Hello, Je viens de publier mon retour sur UGREEN à l’IFA 2026, et il y a une annonce qui mérite vraiment qu’on en discute entre passionnés de domotique : HomeAgent et le nouvel écosystème AIoT de la marque. J’étais allé chez UGREEN en m’attendant surtout à découvrir de nouveaux NAS et accessoires. Il y en a bien, avec notamment les nouveaux DXP6800 Ultra et DXP8800 Ultra. Mais UGREEN a surtout dévoilé quelque chose de beaucoup plus ambitieux. Le HomeAgent HA100 mélange NAS, NVR pour les caméras, contrôleur domotique et IA locale dans une même machine. UGREEN annonce notamment la compatibilité Matter et ONVIF, mais surtout une IA capable d’exploiter localement les informations provenant de la maison. Et c’est là que je trouve le concept particulièrement intéressant. Aujourd’hui, même avec Home Assistant, on passe encore beaucoup de temps à construire nos automatisations : si telle personne est présente + telle luminosité + telle heure = telle action. Avec HomeAgent, UGREEN veut aller vers une maison capable de comprendre le contexte et une intention exprimée naturellement. Par exemple, dire simplement « je vais me coucher » pourrait permettre au système de comprendre qu’il faut fermer les volets, éteindre certaines lumières, vérifier les accès et adapter le chauffage. Même chose avec la vidéosurveillance : plutôt que de parcourir une timeline pendant vingt minutes, on pourrait demander « quand le livreur est-il passé ? » ou « montre-moi quand le chien était dans le jardin ». Autre très bon point à mes yeux : UGREEN insiste sur le local. Stockage local, calcul local et IA locale. Pour une intelligence artificielle amenée à connaître les habitudes des occupants et à analyser les caméras de la maison, c’est plutôt rassurant. Évidemment, il reste de grosses questions. La première sera l’ouverture réelle de la plateforme. UGREEN annonce Matter et ONVIF, mais face à l’écosystème gigantesque de Home Assistant, il va falloir proposer une compatibilité très large pour convaincre les passionnés que nous sommes. Et puis il y a le prix : 899 $ pour le HA100 en Super Early Bird, sans les disques ni les autres équipements. Si le tarif normal approche ensuite les 1 800 $, ça risque de réserver la solution à un public assez averti. Malgré ça, c’est probablement l’une des annonces domotiques qui m’a le plus intrigué sur cet IFA. Ça fait longtemps qu’on parle de « maison intelligente », alors que dans les faits nous programmons encore nous-mêmes la majorité de son intelligence. L’arrivée de modèles IA locaux suffisamment puissants pourrait enfin changer cette logique. J’ai détaillé HomeAgent, le futur HA100 Pro, les caméras SynCare, le MasterAgent sous NVIDIA Jetson Thor, mais aussi les nouveaux NAS et accessoires UGREEN dans l’article : Maison et DomotiqueUGREEN AIoT : quand le NAS, l’IA et la domotique ne font...À l’IFA 2026, UGREEN dévoile HomeAgent, un hub combinant NAS, IA locale, vidéosurveillance et domotique. Une vision très ambitieuse de la maison intelligente. Je suis curieux d’avoir votre avis, notamment les utilisateurs de Home Assistant : vous pourriez envisager ce genre de solution clé en main, ou vous préféreriez voir cette puissance IA arriver sous forme d’intégrations ouvertes pour conserver HA au centre de l’installation ?
Hello ! Home Assistant 2026.9 est sorti pour la rentrée, et je viens de faire le tour des principales nouveautés. Pas forcément de grosse fonction « wahou » cette fois, mais pas mal d'améliorations que je trouve vraiment utiles au quotidien, surtout quand l'installation commence à devenir conséquente. Celle que je retiens en premier, c'est la possibilité de mieux comprendre l'origine d'un changement d'état. Une lumière s'allume sans raison apparente, un volet se ferme tout seul ? L'activité permet maintenant de remonter plus facilement à l'automatisation et au déclencheur responsables. Quand on commence à avoir quelques dizaines d'automatisations, ça peut éviter de longues séances de recherche Autre nouveauté que je vais suivre de près : la modernisation de Modbus. Home Assistant commence à faciliter sérieusement son intégration, notamment avec la possibilité pour plusieurs intégrations de partager une même connexion. Avec tous les onduleurs photovoltaïques, compteurs, PAC et autres équipements énergétiques qui utilisent encore Modbus, ça pourrait devenir très intéressant. On trouve aussi une carte permettant de visualiser le réseau Matter/Thread, des outils MQTT plus accessibles, un panneau pour identifier plus facilement les ports série et les intégrations qui les utilisent, de nouvelles alertes dans le tableau de bord Sécurité, ainsi que plusieurs améliorations des cartes Tuiles. J'ai également bien aimé le petit avertissement avant un redémarrage : Home Assistant indique maintenant si des automatisations ou scripts sont encore en cours d'exécution. Ça peut éviter quelques surprises ;-) J'ai détaillé tout ça, avec quelques exemples d'utilisation, dans l'article : Maison et DomotiqueHome Assistant 2026.9 : une rentrée chargée avec Matter,...Home Assistant 2026.9 est disponible ! Découvrez les nouveautés de septembre : réseau Matter, Modbus simplifié, historique intelligent, sécurité, MQTT et nouvelles cartes Tuiles. Pour ceux qui ont déjà fait la mise à jour, vous retenez quoi de cette 2026.9 ? Personnellement, le suivi plus précis de l'origine des actions et l'évolution de Modbus sont probablement les deux points que je vais surveiller le plus.
Bonjour a tous
Je me présente: JMarie
Présentation
