  2. Igbinedion University Okada POST UTME 2026/2027 ADMISSION FORM Is Out Call ☎️ (0)9165949470 or 09165949470 to Apply The Sales of Jupeb/Post Utme form, Pre-degree Form, Ijmb Form, Jupeb Form, Master Form, Inter-school Transfer Form for more Information On How to apply and admission Assistance. Forms into other programmes are also now available. Contact 09165949470 the school Admin - 09165949470 for more inquiries. The School Authority requires all candidates applying for admission into any of its courses to possess Five (5) O’ Level Credit Level Passes at not more than two (2) sittings to include English Language and Mathematics and three (3) other subjects relevant to course.
  3. Babcock University,Ilishan-Remo POST UTME 2026/2027 ADMISSION FORM Is Out Call ☎️ (0)9165949470 or 09165949470 to Apply The Sales of Jupeb/Post Utme form, Pre-degree Form, Ijmb Form, Jupeb Form, Master Form, Inter-school Transfer Form for more Information On How to apply and admission Assistance. Forms into other programmes are also now available. Contact 09165949470 the school Admin - 09165949470 for more inquiries. The School Authority requires all candidates applying for admission into any of its courses to possess Five (5) O’ Level Credit Level Passes at not more than two (2) sittings to include English Language and Mathematics and three (3) other subjects relevant to course.
  4. Madonna University, Okija POST UTME 2026/2027 ADMISSION FORM Is Out Call ☎️ (0)9165949470 or 09165949470 to Apply The Sales of Jupeb/Post Utme form, Pre-degree Form, Ijmb Form, Jupeb Form, Master Form, Inter-school Transfer Form for more Information On How to apply and admission Assistance. Forms into other programmes are also now available. Contact 09165949470 the school Admin - 09165949470 for more inquiries. The School Authority requires all candidates applying for admission into any of its courses to possess Five (5) O’ Level Credit Level Passes at not more than two (2) sittings to include English Language and Mathematics and three (3) other subjects relevant to course.
  5. information75 a rejoint la communauté
  7. BCS24 a rejoint la communauté
  8. Bonjour, Un répéteur Wi‑Fi installé à l’intérieur fonctionne rarement correctement jusqu’au fond d’un grand jardin, surtout lorsque le signal doit traverser plusieurs murs. La solution la plus stable serait plutôt un point d’accès Wi‑Fi extérieur, résistant aux intempéries, placé en hauteur sur la façade orientée vers le jardin. Si la distance est importante, l’idéal est de relier ce point d’accès à la box par câble Ethernet. À défaut, un système Wi‑Fi Mesh avec une borne proche d’une fenêtre peut améliorer la couverture, mais ses performances dépendront toujours des obstacles. Le CPL peut aussi être envisagé si l’installation électrique du local extérieur est compatible. Avant tout achat, je vérifierais également si le robot a réellement besoin d’une connexion Wi‑Fi permanente pendant la tonte. Certains modèles utilisent le Wi‑Fi principalement pour les mises à jour, la configuration et la consultation à distance, puis travaillent de manière autonome grâce au RTK, au LiDAR ou à leur cartographie enregistrée. Quelle est approximativement la distance entre la maison et le fond du jardin ? Et le robot doit-il contourner un bâtiment ou des murs épais ? Bonjour, Un répéteur Wi‑Fi installé à l’intérieur fonctionne rarement correctement jusqu’au fond d’un grand jardin, surtout lorsque le signal doit traverser plusieurs murs. La solution la plus stable serait plutôt un point d’accès Wi‑Fi extérieur, résistant aux intempéries, placé en hauteur sur la façade orientée vers le jardin. Si la distance est importante, l’idéal est de relier ce point d’accès à la box par câble Ethernet. À défaut, un système Wi‑Fi Mesh avec une borne proche d’une fenêtre peut améliorer la couverture, mais ses performances dépendront toujours des obstacles. Le CPL peut aussi être envisagé si l’installation électrique du local extérieur est compatible. Avant tout achat, je vérifierais également si le robot a réellement besoin d’une connexion Wi‑Fi permanente pendant la tonte. Certains modèles utilisent le Wi‑Fi principalement pour les mises à jour, la configuration et la consultation à distance, puis travaillent de manière autonome grâce au RTK, au LiDAR ou à leur cartographie enregistrée. Quelle est approximativement la distance entre la maison et le fond du jardin ? Et le robot doit-il contourner un bâtiment ou des murs épais ?
  9. RobotExterieur a modifié sa photo de profil
  10. Bonjour à tous, Le choix dépend surtout de la configuration du jardin, pas uniquement de sa surface. Le RTK est très précis lorsque le ciel est bien dégagé, mais il peut devenir moins stable sous des arbres denses, près de murs élevés ou entre deux bâtiments. Le LiDAR dépend moins des satellites et peut être plus adapté aux jardins ombragés ou complexes, mais sa fiabilité varie selon la qualité de la cartographie et des capteurs. Le câble périphérique reste une solution fiable et éprouvée, mais son installation est plus longue et une coupure du câble peut être difficile à localiser. Pour un terrain complexe, les systèmes hybrides combinant RTK, caméra et détection d’obstacles me semblent actuellement les plus polyvalents. Avant de choisir, je regarderais surtout : la densité des arbres, la hauteur des murs, la largeur des passages, le nombre de zones et la pente réelle du terrain. Pour ceux qui utilisent déjà un modèle sans fil, avez-vous remarqué des pertes de position sous les arbres ou près de la maison ?
  11. RobotExterieur a rejoint la communauté
  12. La semaine dernière
  13. chitou a rejoint la communauté
  14. # Dito Ton exemple de notification actions: - action: notify.send_message # n'utilise pas ton module? metadata: {} data: message: Alarme activer ! target: entity_id: - notify.maman # Il faudrait expliquer comment tu trouves notify.maman # Si je prends un exemple d'automatisation, cela ne fonctionne pas. Déja il faut trouver la target notify action: freesmsxa.send_sms enabled: false data: target: notify.free_mobile_sms_5g_5g message: 'UPS a changé d''état ' # et j'ai une jolie trace File "/config/custom_components/freesmsxa/__init__.py", line 29, in handle_send_sms if target not in hass.services.services.get("notify", {}): ^^^^^^^^^^^^^^^^^^^^^^ File "/usr/src/homeassistant/homeassistant/core.py", line 2633, in services return run_callback_threadsafe(self._hass.loop, self.async_services).result() ~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/src/homeassistant/homeassistant/util/async_.py", line 58, in run_callback_threadsafe raise RuntimeError("Cannot be called from within the event loop") RuntimeError: Cannot be called from within the event loop
  15. Bonjour à Tous j'ai un problème de mise à jour sur mon vieux MyOpen de Legrand/BTicino, F454 (qui date de 2012) qui tourne en 1.0.32 impossible à passer en 2.0.51 avec myhomesuite legrand après de nombreuse recherche il me faut un firmware intermédiaire j'ai besoin du firmware 1.0.51 si quelqu'un connaissait quelqu'un qui a le même serveur et le firmware 1.0.51 je serait preneur s'il vous plait!! car le service client de Legrand me dit qu'ils n'ont plus les firmware..... merci pour vos réponses Damien
  16. Bonjour à tous. Je me Prénome ManGhost car j'aime les technologies passionné par l'informatique l'électronique et la mécanique automobile et le modélisme quelqu'un d'autodidacte quand cela me passionne. J'ai 38 ans et je viens ici pour étoffer ma connaissance dans la domotique je possède déjà une multitude d'appareils domotique et je souhaiterais en apprendre d'avantage. Merci pour l'inscription au plaisir d'échanger
  17. Avant
  18. Salut à tous, Je reviens de l’IFA de Berlin, où je suis notamment passé sur le stand Aqara. Et cette année, pas de nouveau petit capteur vedette : la marque s’attaque franchement à l’éclairage connecté, aussi bien à l’intérieur qu’à l’extérieur. Cinq nouveautés étaient présentées : la Floor Lamp T1, une lampe verticale avec 18 zones lumineuses indépendantes, le LED Strip T2 avec ses 108 LED/m, le Downlight T2 pour les spots encastrés, ainsi que les Outdoor String Lights H1 et Permanent Outdoor Lights H1 pour le jardin et les façades. Le choix technique est plutôt intéressant pour nous autres amateurs de domotique : tous ces éclairages proposent Thread ET Zigbee. On peut donc partir sur Thread/Matter pour les intégrer à Home Assistant, Apple Home, Google Home, etc., ou rester en Zigbee pour profiter des fonctions et automatisations plus poussées d’Aqara Home. Sur le stand, Aqara avait justement recréé une véritable pièce à vivre pour montrer l’interaction entre les éclairages, les capteurs, les interrupteurs et le Cube T1 Pro. C’est beaucoup plus parlant que quelques ampoules alignées sur une étagère : on voit bien que l’objectif est désormais de faire varier automatiquement toute l’ambiance d’une pièce selon la présence ou le scénario en cours. J’ai regroupé les caractéristiques des cinq produits et mes impressions après les avoir vus fonctionner à Berlin dans l’article : Maison et DomotiqueIFA 2026 : Aqara étend son écosystème avec des éclairages...À l'IFA 2026 de Berlin, Aqara dévoile cinq nouveaux éclairages connectés Thread, Zigbee et Matter pour équiper la maison et le jardin. Personnellement, le double choix Thread/Zigbee me paraît être l’un des points les plus intéressants de cette nouvelle gamme. Et les Permanent Outdoor Lights H1 me font déjà imaginer quelques scénarios sympas autour de la maison 😅 Curieux d’avoir votre avis : parmi ces nouveautés, laquelle vous tenterait le plus ? Et pour ce type d’éclairage, vous partiriez plutôt sur Matter/Thread ou Zigbee ?
  19. Salut à tous, De retour de l’IFA 2026 à Berlin, je continue mon tour des nouveautés avec cette fois EZVIZ. Et j’avoue avoir été assez surpris par l’évolution de la marque. On connaît surtout EZVIZ pour ses caméras, mais leur écosystème commence à aller beaucoup plus loin. J’ai notamment découvert les nouvelles H90f et HB90f avec trois objectifs, capables de conserver une vue globale tout en allant chercher un détail avec un zoom mixte jusqu’à 12x. 👀 Mais le plus intéressant pour nous, amateurs de domotique, est probablement AI CoreX. 🧠 Il s’agit d’un véritable cerveau local qui combine stockage et IA : reconnaissance des personnes, recherche intelligente dans les vidéos, résumé des événements de la journée… avec une approche « local-first » qui limite la dépendance au cloud. C’est clairement la partie que j’ai trouvée la plus prometteuse. EZVIZ pousse également très fort sur les accès : reconnaissance faciale et palmaire, visiophones 4K, sonnette avec détection des colis, motorisation du portail, sans oublier les caméras Wi-Fi/4G pour les endroits éloignés de la maison. J’ai pu voir et manipuler pas mal de ces nouveautés directement sur le stand, et j’ai regroupé tout ça dans mon compte rendu : Maison et DomotiqueIFA 2026 : EZVIZ ne veut plus seulement surveiller votre...À l’IFA 2026, EZVIZ dévoile ses caméras triple objectif H90f et HB90f, l’IA locale AI CoreX, des accès biométriques et un écosystème maison toujours plus complet. Reste pour moi une grosse question : jusqu’où EZVIZ ouvrira-t-il cet écosystème à Home Assistant et aux autres solutions domotiques ? Car avec davantage d’IA et de traitements locaux, il y aurait vraiment des choses intéressantes à faire… Vous en pensez quoi ? L’IA locale dans la vidéosurveillance vous intéresse, ou vous préférez conserver caméras, NVR/NAS et domotique dans des systèmes indépendants ?
  20. Merci Pierre, tu confirmes ce que je pressentais sur les cartes WiFi des box, souvent limites. L'idée de la borne WiFi je la retiens, c'est clairement plus costaud que le WiFi de la box. D'ailleurs mon voisin, un vieux pépé pourtant pas du tout branché technique, a installé un point d'accès wifi extérieur directionnelle pour couvrir sa serre située à 150 mètres de sa maison, en vue directe. Franchement ça marche du tonnerre chez lui : il a du WiFi stable jusqu'au fond de son terrain, et il pilote son arrosage et ses capteurs de serre sans souci. Si lui y arrive, ça me rassure pour mon robot au fond du jardin. Le câble Ethernet jusqu'à la zone de tonte, chez moi c'est la croix et la bannière : une allée bétonnée et un massif à traverser, pas envie de faire une tranchée juste pour ça. Une borne extérieure de ce type, posée en hauteur et orientée vers la zone du robot, ça m'éviterait tout ça tout en couvrant le reste du terrain pour les mobiles — exactement ton idée, mais sans tirer de câble. Je vais tester l'AP wifi en extérieur et vous dirait quoi après ...
  21. Salut à tous, Je viens de publier mon compte rendu des nouveautés Shelly découvertes à l’IFA 2026 de Berlin, et il y a franchement pas mal de choses intéressantes cette année. Shelly ne se contente clairement plus de ses fameux micromodules. On retrouve bien sûr les nouveaux 1L et 2L Gen4 fonctionnant sans neutre, avec Wi-Fi, Zigbee, Bluetooth et Matter, mais la gamme s’étend maintenant dans beaucoup de directions. La nouveauté qui m’intéresse probablement le plus est le Shelly Presence Gen4 et sa détection mmWave. Contrairement à un PIR qui détecte surtout un mouvement, celui-ci peut savoir si quelqu’un est toujours présent dans une pièce même sans beaucoup bouger. Pour nos scénarios Home Assistant, Jeedom, etc., c’est autrement plus intéressant dans un salon, un bureau ou une salle de bains. J’ai également découvert la nouvelle serrure LOQED Pure, les capteurs BLU Zigbee (dont enfin un détecteur d’ouverture extérieur IP55 !), la nouvelle BLU TRV, le compteur EM-63 Gen4, le Wall Display X1i et une petite caméra à 39 € annoncée compatible Home Assistant et Frigate. Autre curiosité : les drivers LED HiluX Powered by Shelly permettent de rendre connectées des dalles ou autres luminaires existants en remplaçant simplement leur driver. Ça devrait surtout intéresser les installations tertiaires. J’ai aussi pu discuter plus librement avec l’un des responsables Shelly de leur stratégie autour de Zigbee, Matter, du retrofit et de l’importance de conserver des commandes physiques qui fonctionnent même sans domotique. J’ai intégré quelques éléments de cette discussion à l’article. 👉 Article complet : Maison et DomotiqueShelly frappe fort à l’IFA : modules sans neutre, Zigbee,...À l’IFA 2026, Shelly dévoile ses nouveautés : Gen4 sans neutre, capteurs Zigbee, Wall Display X1i, BLU TRV, caméra, énergie et éclairage HiluX. Personnellement, le Presence Gen4 est vraiment celui que j’ai envie de tester. Et vous, quelle nouveauté vous semble la plus intéressante ?
  22. Salut à tous, Je suis actuellement à Berlin pour couvrir l’IFA et j’ai assisté à la conférence de BLUETTI. J’avais déjà découvert la nouvelle gamme Balco lors d’une présentation à Paris, et j’utilise depuis quelque temps le Balco 260 + BC260 chez moi pour stocker mon surplus photovoltaïque. À l’IFA, la stratégie de BLUETTI devient beaucoup plus claire : la marque ne veut plus simplement vendre des power stations, mais construire un véritable écosystème énergétique pour la maison. Parmi les nouveautés intéressantes : 🔋 Balco 500 : 5 kWh de stockage, jusqu’à 4,6 kW de PV et 3,68 kW en sortie. On commence sérieusement à s’éloigner du simple kit solaire de balcon ! 🤖 BlueBot : une IA qui analyse production solaire, consommation, météo, tarifs électriques et état des batteries pour optimiser automatiquement l’énergie de la maison. 🔌 EnergyFlex / Balco Transfer : une idée que je trouve particulièrement sympa puisqu’elle permet d’utiliser une power station comme batterie domestique, puis de la débrancher pour l’emmener en voyage. 🏠 BLUETTI Space : jusqu’à six unités peuvent travailler ensemble pour constituer un stockage distribué dans la maison. 🏗️ Pioneer 5000 E-Generator : beaucoup plus orienté pro, avec 5 kW continus et surtout 18 kW en pointe pour alimenter des machines de chantier. GPS et 4G sont même prévus sur certaines versions. 🎒 Elite Mini : trois nouvelles power stations plus compactes et légères. Ce qui m’intéresse surtout dans cette évolution, c’est la partie HEMS. Les batteries savent maintenant très bien stocker des kWh ; le prochain enjeu est de décider intelligemment quand les charger et les décharger. Ayant justement testé le Balco 260 sur ma propre installation, j’ai essayé dans l’article de faire le lien entre ce qui existe déjà et la direction prise par BLUETTI avec le Balco 500 et BlueBot. 👉 Article complet : Maison et DomotiqueBLUETTI à l’IFA 2026 : Balco 500, BlueBot, Pioneer 5000…...À l’IFA 2026, BLUETTI dévoile le Balco 500, BlueBot, le Pioneer 5000 et sa nouvelle vision d’un écosystème énergétique intelligent. Je serais curieux d’avoir votre avis, notamment sur BlueBot : est-ce que vous seriez prêts à laisser une IA gérer automatiquement votre batterie en fonction de la météo, des tarifs et de vos habitudes ? Ou vous préférez garder la main avec vos propres automatisations Home Assistant / Jeedom ? 😉
  23. Bonjour, actuellement en phase de lecture du contenu du forum. Dès assimilation je reviendrai poser d'éventuelles questions. Claude
  24. claude72230 a commencé à suivre Présentez-vous
  25. Hello, Je viens de publier mon retour sur UGREEN à l’IFA 2026, et il y a une annonce qui mérite vraiment qu’on en discute entre passionnés de domotique : HomeAgent et le nouvel écosystème AIoT de la marque. J’étais allé chez UGREEN en m’attendant surtout à découvrir de nouveaux NAS et accessoires. Il y en a bien, avec notamment les nouveaux DXP6800 Ultra et DXP8800 Ultra. Mais UGREEN a surtout dévoilé quelque chose de beaucoup plus ambitieux. Le HomeAgent HA100 mélange NAS, NVR pour les caméras, contrôleur domotique et IA locale dans une même machine. UGREEN annonce notamment la compatibilité Matter et ONVIF, mais surtout une IA capable d’exploiter localement les informations provenant de la maison. Et c’est là que je trouve le concept particulièrement intéressant. Aujourd’hui, même avec Home Assistant, on passe encore beaucoup de temps à construire nos automatisations : si telle personne est présente + telle luminosité + telle heure = telle action. Avec HomeAgent, UGREEN veut aller vers une maison capable de comprendre le contexte et une intention exprimée naturellement. Par exemple, dire simplement « je vais me coucher » pourrait permettre au système de comprendre qu’il faut fermer les volets, éteindre certaines lumières, vérifier les accès et adapter le chauffage. Même chose avec la vidéosurveillance : plutôt que de parcourir une timeline pendant vingt minutes, on pourrait demander « quand le livreur est-il passé ? » ou « montre-moi quand le chien était dans le jardin ». Autre très bon point à mes yeux : UGREEN insiste sur le local. Stockage local, calcul local et IA locale. Pour une intelligence artificielle amenée à connaître les habitudes des occupants et à analyser les caméras de la maison, c’est plutôt rassurant. Évidemment, il reste de grosses questions. La première sera l’ouverture réelle de la plateforme. UGREEN annonce Matter et ONVIF, mais face à l’écosystème gigantesque de Home Assistant, il va falloir proposer une compatibilité très large pour convaincre les passionnés que nous sommes. Et puis il y a le prix : 899 $ pour le HA100 en Super Early Bird, sans les disques ni les autres équipements. Si le tarif normal approche ensuite les 1 800 $, ça risque de réserver la solution à un public assez averti. Malgré ça, c’est probablement l’une des annonces domotiques qui m’a le plus intrigué sur cet IFA. Ça fait longtemps qu’on parle de « maison intelligente », alors que dans les faits nous programmons encore nous-mêmes la majorité de son intelligence. L’arrivée de modèles IA locaux suffisamment puissants pourrait enfin changer cette logique. J’ai détaillé HomeAgent, le futur HA100 Pro, les caméras SynCare, le MasterAgent sous NVIDIA Jetson Thor, mais aussi les nouveaux NAS et accessoires UGREEN dans l’article : Maison et DomotiqueUGREEN AIoT : quand le NAS, l’IA et la domotique ne font...À l’IFA 2026, UGREEN dévoile HomeAgent, un hub combinant NAS, IA locale, vidéosurveillance et domotique. Une vision très ambitieuse de la maison intelligente. Je suis curieux d’avoir votre avis, notamment les utilisateurs de Home Assistant : vous pourriez envisager ce genre de solution clé en main, ou vous préféreriez voir cette puissance IA arriver sous forme d’intégrations ouvertes pour conserver HA au centre de l’installation ?
  26. Bonjour, Ma demande pourra certainement paraitre simpliste pour certains : je dispose d'un poele à pellets dont le ventilateur tangentiel de soufflage n'a pas de variation de vitesse. Comme c'est un moteur asynchrone, j'ai mis en place un commutateur qui aliment le moteur soit en direct sur le secteur soit qui bascule sur un circuit avec un condensateur de 1.3µF. Pour l'instant c'est manuellement que j'agis sur le commutateur (un inter de va-et-vient). Je souhaiterais pouvoir commander par smartphone (appli Tuya) ce dispositif en remplaçant mon interrupteur manuel. Quel dispositif pourrait me rendre le service, sachant que je souhaiterais qu'il puisse être commandé par un scénario différé sur le micromodule de démarrage de mon poêle, à la mise en route comme à l'arrêt ? Merci et à votre disposition pour donner des détails si je n'ai pas été assez clair
  27. Hello ! Home Assistant 2026.9 est sorti pour la rentrée, et je viens de faire le tour des principales nouveautés. Pas forcément de grosse fonction « wahou » cette fois, mais pas mal d'améliorations que je trouve vraiment utiles au quotidien, surtout quand l'installation commence à devenir conséquente. Celle que je retiens en premier, c'est la possibilité de mieux comprendre l'origine d'un changement d'état. Une lumière s'allume sans raison apparente, un volet se ferme tout seul ? L'activité permet maintenant de remonter plus facilement à l'automatisation et au déclencheur responsables. Quand on commence à avoir quelques dizaines d'automatisations, ça peut éviter de longues séances de recherche Autre nouveauté que je vais suivre de près : la modernisation de Modbus. Home Assistant commence à faciliter sérieusement son intégration, notamment avec la possibilité pour plusieurs intégrations de partager une même connexion. Avec tous les onduleurs photovoltaïques, compteurs, PAC et autres équipements énergétiques qui utilisent encore Modbus, ça pourrait devenir très intéressant. On trouve aussi une carte permettant de visualiser le réseau Matter/Thread, des outils MQTT plus accessibles, un panneau pour identifier plus facilement les ports série et les intégrations qui les utilisent, de nouvelles alertes dans le tableau de bord Sécurité, ainsi que plusieurs améliorations des cartes Tuiles. J'ai également bien aimé le petit avertissement avant un redémarrage : Home Assistant indique maintenant si des automatisations ou scripts sont encore en cours d'exécution. Ça peut éviter quelques surprises ;-) J'ai détaillé tout ça, avec quelques exemples d'utilisation, dans l'article : Maison et DomotiqueHome Assistant 2026.9 : une rentrée chargée avec Matter,...Home Assistant 2026.9 est disponible ! Découvrez les nouveautés de septembre : réseau Matter, Modbus simplifié, historique intelligent, sécurité, MQTT et nouvelles cartes Tuiles. Pour ceux qui ont déjà fait la mise à jour, vous retenez quoi de cette 2026.9 ? Personnellement, le suivi plus précis de l'origine des actions et l'évolution de Modbus sont probablement les deux points que je vais surveiller le plus.
  28. Les cartes wifi des boxes sont généralement médiocre, une vraie borne wifi pourrait peut-être arranger le truc. Cela-dit, je pense que j'essaierai plutot d'emmener un câble ethernet pour mettre une borne wifi plus proche (soit une borne extérieur, c'est cher, soit une borne intérieur si un abri de jardin est bien positionné). Outre la couverture pour le robot, ça permet également de couvrir tout le terrain pour les appareils mobiles (smartphones, ordinateurs portables, montres, etc)
  29. Bonjour, ton problème est sans doute dû à la platine alimentation ou il se trouve un petit condensateur qu'il faut remplacer car tu peux le voir il est gonflé.
  30. Bonjour à tous, Je viens d'installer un Mammotion Luba 2 AWD et j'ai un souci que certains ont peut-être déjà rencontré. Ma zone de tonte est assez éloignée de la maison — le robot travaille au fond du terrain, à une bonne cinquantaine de mètres de la box, avec de la végétation entre les deux. Le robot lui-même tond nickel (le RTK fait son boulot), mais côté connexion c'est une autre histoire : dès qu'il s'éloigne, l'appli Mammotion passe en "hors ligne". Résultat, je perds tout ce qui fait l'intérêt du robot connecté : plus de suivi en temps réel de la tonte plus de notifications (fin de tâche, robot bloqué, pluie...) plus de pilotage à distance (démarrer/mettre en pause depuis le canapé ou le boulot) et surtout l'antivol/géolocalisation qui dépend de la connexion Le robot est en WiFi (je n'ai pas pris l'option 4G), donc il se connecte directement à la box — mais la box ne porte tout simplement pas jusqu'au fond du jardin. Comment vous gérez ça quand le robot est loin de la maison ? Je cherche une solution fiable qui tienne dehors et qui me redonne une connexion stable jusqu'à la zone de tonte.
  31. Saggi a posté un sujet dans Présentez-vous
  32. Bonjour à toutes, et tous, JMarie, j'habite à la frontiere du bourgogne et du beaujolais, dans les vignobles du Maconnais. à 57 ans, j'aime bricoler, et je me suis lancer dans la renovation complète d'une ancienne maison de vigneron. Mais je souhaite faire les choses bien, donc je suis actuellement une formation D'electricien en equipement du batiment ; titre professionnel qui inclus un module Electricité generale (terminé) et un block de domotique que je commence. Je m'inscrit sur ce site pour completer ma formation par votre experience au service de ma maison que je souhaite domotiser (portail, alarme, visio, IRVE,...) Voila, merci de votre accueil,
  33. Salut à tous, Je viens de publier mon test de la DJI Power 1000 Mini, une station que je trouve assez intéressante par son positionnement. On a 1 008 Wh de capacité pour seulement 11,5 kg, avec batterie LFP, recharge solaire jusqu’à 400 W, câble USB-C 100 W rétractable, port SDC et pilotage via DJI Home. Pour nos usages domotiques, le mode UPS est également intéressant : on peut laisser une box Internet, un routeur, un NAS, un mini PC ou encore une installation Home Assistant dessus afin de prendre le relais en cas de coupure secteur. 🔋🏠 Le principal compromis vient de la puissance : 800 W en continu, avec un maximum de 1 000 W. On est donc loin des grosses stations capables d'alimenter quasiment toute la maison. Mais pour de l'informatique, de la domotique, du réseau ou des usages nomades, cette limitation permet en contrepartie d'avoir une station 1 kWh particulièrement facile à transporter. J'ai également regardé la recharge secteur, solaire, l'application DJI Home, le fonctionnement en UPS et bien sûr les appareils qu'on peut réellement alimenter avec. 👉 Test complet : Maison et DomotiqueTest DJI Power 1000 Mini : DJI a trouvé le bon compromis...Test complet de la DJI Power 1000 Mini : capacité 1 008 Wh, puissance 1 000 W, recharge solaire, mode UPS, application DJI Home et autonomie réelle. Pour une station de cette capacité, vous privilégieriez quoi de votre côté : 800 W et 11,5 kg, ou davantage de puissance quitte à avoir quelque chose de nettement plus lourd et encombrant ? ⚡
  34. Meme problème ici. ET dans Tydom, ET dans HA, impossible d'ajouter la plupart des volet ID4 RU (neufs).
  35. Bonjour à tous, je suis Clément habitant près de Lille Petite présentation : passionné de bricolage et de maison connectée, je m'intéresse à la domotique et aux petits projets pour rendre le quotidien plus pratique. Je découvre votre forum et j'ai hâte d'échanger et d'apprendre avec vous. Au plaisir !
