{+256747234371 effective black magic spells caster in USA, UK, Turkey, India, German, Finland, Japan ,Italy, Brazil, London
Invité a posté un sujet dans Vos Tests & Retours d’expérience{+256747234371 top leading powerful revenge death spells that work immediate in Usa, Canada, Australia, United Kingdom, Italy, Germany, Norway, Sweden, Lebanon, Cyprus, Denmark, Switzerland, New Zealand, and i can help you to kill ur ex lover within 24 hours, 48 hours and 72 hours with guaranteed results, and i can also help you to kill ur enemies with my combination of voodo doll, black magic that work fast in killing ur enemies , due to my experience in the world i can also help you to bring back ur ex lover within same day process . with all my satisfied client in world am very good in death spells, revenge spells, love spells, attraction love binding spells, Lottery Money Spells, Stop Divorce. AND THERE IS NO BACKFIRE AFTER USING MY STRONG SPELLS -
{+256747234371 leading death spell caster in USA, UK, Turkey, India, German, Finland, Japan ,Italy, Brazil, London ,Iran, Qatar
{+256747234371 OUTSTANDING FOREMOST IMPLIED DEATH SPELLS IN FINLAND MEXICO SWITZERLAND PORTUGAL GREECE COLORADO EUROPE UKRAINE SCOTLAND NORWAY
Invité a posté un sujet dans Vos Tests & Retours d’expérience+256747234371 the best black magic voodoo spell caster in the world today for death spells that work overnight in sleep EFFECTIVE DEATH SPELL CASTER IN ITALY, SPAIN, NETHERLANDS AMSTADAM ,New Zealand, UAE, UK USA NONBACK FIRING VODOO STROKE,ACCIDENT DEATH/ REVENGE SPELL CASTER IN HOLLAND,POLLAND,CANADA,SPAIN, 24 HRS RESULTS TORONTO BEST DEATH SPELL CASTER / REVENGE SPELLS IN CANADA, USA, UK, AUSTRALIA, FINLAND, DENMARK, NORWAY, AUSTRALIA, SWITZERLAND,AUSTRIA, LEBANON, CYPRUS death Sppells in Netherlands, Norway ,Poland ,Portugal, NAMES: PROF MUTI -
+256747234371 Revenge spells that work instantly, spells to make someone sick and palarised, i need revenge death spell caster
{+256747234371 } Top 10 Powerful Black Magic Revenge Spells That Actually Work (Immediate Results)
{+256747234371 } TOP LEADING DEATH/ REVENGE SPELLS THAT WORK OVERNIGHT IN USA, CANADA, AUSTRALIA, UK
{+256747234371 } ONE DAY POWERFUL DEATH SPELLS /REVENGE SPELL THAT WORKS IN USA, CANADA, AUSTRALIA, UK, ITALY
Invité a posté un sujet dans Vos Tests & Retours d’expérience{+256747234371 In USA, Canada, Australia, United Kingdom, Germnay, Italy, Norway, Sweden, Denmark, Cyprus, Switzerland, New Zealand, Austria and other countries in the world For Powerful Lottery Spells and Money Spells to Win the Mega Millions Powerball Jackpot in New York City,New York,Los Angeles California,Chicago,Illinois,Houston,Texas Lottery Spells are very simple spells that can help you with lottery Lottery spells are basically good luck spells to help you win some money with lottery tickets. Stop losing money and make millions from the lottery with lotto spells that work fast. Choose this lotto money spell to receive a large sum of money at the lottery or make someone else receive a large sum of money at the lottery . Win bigger prizes from the lotto with lottery spells that will work in any country. Learn how to increase your chances of winning the lottery with lotto spell for more details -
JPB64 a rejoint la communauté
Bonjour à tous, Je crée ce post pour vous expliquer le problème de déconnexion avec ma sonnette Aqara G4. Je vous propose également la solution que j'ai trouvée, totalement opérationnelle. Aqara Doorbell Camera G400 — Déconnexion nocturne : solution définitive (FR)Problème : Ma sonnette Aqara Doorbell Camera G400 (modèle filaire) se déconnectait chaque nuit, systématiquement, dès l'activation du mode infrarouge (vision nocturne). Elle revenait en ligne automatiquement au lever du soleil, quand le mode nuit se désactivait. Un symptôme très caractéristique : si votre G400 est offline le matin mais revient toute seule dans la journée, c'est très probablement ce problème. Cause identifiée : Le transformateur d'origine du carillon Legrand (petit module Myrra intégré) était sous-dimensionné pour alimenter correctement la G400 en mode infrarouge, qui consomme davantage qu'en mode normal. La sonnette ne recevait pas assez de puissance et se déconnectait pendant toute la durée de la nuit. Confirmation Aqara : J'ai contacté le support Aqara, qui a confirmé les spécifications d'alimentation externe de la G400 : Tension acceptée : 8 à 24V AC / 1,3A — ou 8 à 24V DC / 0,8A Puissance minimale recommandée pour 24V AC : 12 VA En 24V AC, un transfo de 30 VA couvre largement, même en mode infrarouge Solution retenue : Remplacement du transformateur Myrra d'origine par un Vemer TMC 30/24 (réf. VN319000) : Sortie : 24V AC — 30 VA Format : rail DIN (3 modules) Compatible et confirmé par Aqara Installation : Vidage complet du boîtier carillon existant (PCB et mécanisme Legrand retirés — inutiles avec la G400 filaire) Vissage d'un court tronçon de rail DIN 35mm au fond du boîtier Clipsage du transfo Vemer sur le rail Connexion du 230V existant (phase + neutre) sur les bornes primaires du transfo Connexion des deux fils du secondaire (24V AC) sur les bornes d'alimentation externe de la G400 — sans polarité à respecter Le capot d'origine étant trop peu profond, impression 3D d'un capot sur mesure Résultat : Testé en forçant le mode infrarouge — aucune déconnexion. Problème résolu définitivement.
Bonjour a tous, Je fais du depannage informatique a domicile depuis plusieurs annees (particuliers et petites structures), et je vois revenir un scenario presque toutes les semaines chez des clients qui ont investi dans la domotique : du jour au lendemain, plus rien ne repond. Les ampoules restent bloquees sur le dernier etat, les capteurs passent "indisponible", l'appli n'affiche plus rien de coherent. Le reflexe immediat est souvent de tout reinitialiser (box, hub, voire les objets un par un), alors que 9 fois sur 10 le probleme vient d'un maillon reseau bien precis, pas des objets connectes eux-memes. Je partage ici la methode que j'utilise pour trouver le vrai coupable avant de tout casser. 1. Isoler : est-ce vraiment tout qui est down, ou juste une partie ? Avant tout diagnostic, je regarde si le probleme touche uniquement le WiFi 2,4 GHz (souvent celui des objets connectes, alors que les ordinateurs/smartphones basculent sur le 5 GHz sans qu'on s'en rende compte) ou vraiment tout le reseau. Un test simple : un appareil filaire (PC en Ethernet, box elle-meme) a-t-il toujours acces a Internet ? Si oui, le probleme est localise au WiFi, pas a la ligne. Si meme le filaire est mort, on remonte plus haut (box, operateur). 2. Le hub/passerelle domotique a-t-il vraiment perdu la connexion, ou juste le cloud ? Beaucoup de solutions (Home Assistant en local excepte) dependent d'un serveur cloud du fabricant. Une coupure de ce cloud (chez l'editeur, pas chez vous) donne exactement les memes symptomes qu'une panne reseau locale : plus aucune reponse dans l'appli. Avant de toucher a quoi que ce soit chez vous, je verifie toujours la page de statut du service concerne et les forums/reseaux sociaux du fabricant pour voir si d'autres utilisateurs remontent le meme souci au meme moment. Ca evite de reinitialiser un hub qui n'a strictement rien. 3. Le DHCP et les adresses IP : le coupable silencieux Un classique que je retrouve tres souvent chez les clients : la box redistribue les adresses IP au fil du temps (bail DHCP), et un objet connecte qui avait une IP fixe "en dur" cote automatisation se retrouve avec une IP differente apres un redemarrage de box. Resultat : le hub essaie de parler a une adresse qui ne correspond plus au bon appareil. Le symptome est trompeur, on dirait que l'objet est hors ligne alors qu'il fonctionne tres bien sur une autre IP. Reserver les IP des equipements domotique critiques dans les parametres de la box (reservation DHCP par adresse MAC) regle ce probleme une fois pour toutes. 4. Le WiFi 2,4 GHz sature par le voisinage Avec la multiplication des objets connectes (et de plus en plus de box/routeurs autour de nous en habitat collectif), le canal WiFi 2,4 GHz que vous utilisez peut se retrouver sature par les reseaux voisins, provoquant des pertes de paquets intermittentes plutot qu'une vraie coupure. C'est un cas particulierement difficile a diagnostiquer parce que "ca remarche tout seul" de temps en temps, ce qui pousse a croire que le probleme est resolu alors qu'il va revenir. Un scan des canaux WiFi environnants permet de choisir un canal moins encombre et de stabiliser nettement la connexion des objets les plus sensibles. 5. Firmware du hub/box a jour ? Dernier point, souvent neglige : certains bugs de compatibilite entre le firmware de la box/du routeur et celui du hub domotique apparaissent apres une mise a jour de l'un des deux. Si le probleme est arrive "d'un coup" sans manipulation de votre part, ca vaut le coup de verifier les notes de version recentes du fabricant du hub pour voir si un bug de ce type est documente et deja corrige dans une mise a jour suivante. En resume : avant de reinitialiser quoi que ce soit, je recommande cet ordre de verification : filaire vs WiFi, statut cloud de l'editeur, reservation DHCP, encombrement du canal WiFi, firmware. Dans mon experience de terrain, ca resout la grande majorite des cas sans perdre toutes les automatisations configurees (ce qui arrive malheureusement souvent apres une reinitialisation complete faite dans la precipitation). Si apres tout ca le probleme persiste, c'est probablement plus profond dans la configuration reseau (segmentation VLAN, QoS mal reglee...) et la ca vaut le coup de se faire accompagner, j'ai d'ailleurs detaille une partie de ce diagnostic reseau plus en profondeur sur une page dediee de mon site pour ceux que ca interesse. Bonne chasse aux pannes, et n'hesitez pas a partager vos propres retours d'experience sur des cas plus tordus, je suis preneur !
Bon, finalement j'ai résolu le problème : Ce modèle de bouton poussoir sans fil Zigbee "Moes" (ZT-SY-EU1S-WH-EN) porte la référence TS0041 (_TZ3000_22ugzkme) est en fait un interrupteur Tuya réétiqueté par Moes. Ce modèle précis souffre d'un bug connu dans certaines versions de “HA” et de Zigbee2MQTT, où le "device configuration" envoyé par MQTT n'associe pas correctement l'entité d'action à l'appareil.“ Pour contourner ce problème, il faut déclarer manuellement l‘entité “action” dans “HA”, en ajoutant le code suivant dans le fichier “configuration.yaml” : mqtt: sensor: - name: "MOES1 Action" unique_id: moes1_action_bouton_custom state_topic: "zigbee2mqtt/MOES1" value_template: "{{ value_json.action }}" icon: "mdi:gesture-tap-button" expire_after: 1 # <-- Remet le capteur à zéro après 1 seconde Après quoi, il est possible de l’utiliser dans une automatisation. Ci-dessous un exemple de test qui fait changer l’état d'une lampe, quelque soit l’action sur le bouton (appui simple, double ou maintenu) : alias: Test MOES1 description: "Inverse l’état de la lampe de la salle à manger, à chaque appui sur le bouton (simple, double ou maintenu). Gestion par l'entité sensor_action (liée au code ajouté dans le configuration.yaml, à l'étiquette mqtt:)." triggers: - id: appui_simple trigger: mqtt options: topic: zigbee2mqtt/MOES1 payload: single value_template: "{{ value_json.action }}" - id: appui_double trigger: mqtt options: topic: zigbee2mqtt/MOES1 payload: double value_template: "{{ value_json.action }}" - id: appui_long trigger: mqtt options: topic: zigbee2mqtt/MOES1 payload: hold value_template: "{{ value_json.action }}" conditions: [] actions: - choose: - conditions: - condition: trigger id: appui_simple sequence: - action: switch.toggle metadata: {} target: entity_id: switch.douille_lampe data: {} - conditions: - condition: trigger id: appui_double sequence: - action: switch.toggle metadata: {} target: entity_id: switch.douille_lampe data: {} - conditions: - condition: trigger id: appui_long sequence: - action: switch.toggle metadata: {} target: entity_id: switch.douille_lampe data: {} Bref, une belle galère pour moi qui ne suis pas un spécialiste ! Je regrette l'achat de ce bouton, surtout si on le compare à celui d'AQARA (WRS-R02) un peu plus cher et qui n'existe malheureusement qu'en version "double poussoir", mais dont l'intégration dans Z2M est immédiate.
