Home Assistant 2026.2 : la mise à jour de février 2026 rend le dashboard Home par défaut et lance la Device Database
My name is Darlene M, and I never imagined my life could change so fast. I was struggling with some unpaid bills and financial stress for years, and I was constantly wondering how people are able to win the lottery so big because I sometimes play the lottery but never won any big amount, I sought spiritual guidance from Chief Ade after I heard about him, how he has been helping people with the lottery winning numbers, and not long afterwards I won the $16,000,000 MILLION Lotto 6/49 Gold Ball jackpot with the numbers he gave me. That incredible win completely transformed my life. I was able to pay off all my debts, purchase a brand-new truck, and make sure my children had everything they needed to pursue their dreams. I also chose to share my good fortune by supporting local charities and helping families in need, because I know what it's like to struggle. I'm sharing this to remind whosoever seeing this that hope can inspire people to keep believing, even during difficult times. Email : [email protected] || Whats App +234 901 380 6328
Prime Day Mammotion : promos sur les robots tondeuses Yuka Mini 2
Test Oakywood : mon avis après plusieurs semaines à travailler sur ce bureau
Test et avis Aqara U200 : une serrure Matter et Thread vraiment taillée pour Home Assistant
Test Segway Navimow i108E : un mois avec la tondeuse robot sans câble périmétrique
Test SwitchBot S20 : mon avis complet sur cet aspirateur robot laveur au super rapport qualité-prix
Test SwitchBot K11+ : mon avis sur le mini-aspirateur robot connecté Matter et Home Assistant
Home Assistant 2026.3 : Un "grand nettoyage" bienvenu et plein de pépites communautaires
Test Aiper Scuba V3 : notre avis sur le robot de piscine sans fil dopé à l’IA
chloevagabond a rejoint la communauté
Radobdm a rejoint la communauté
philipppe1 a rejoint la communauté
Leon a rejoint la communauté
ikonomoff a rejoint la communauté
dmars a rejoint la communauté
SELLE a rejoint la communauté
corentin570 a commencé à suivre Domotiser une chaudière avec régulation
Compteur shelly
Compteur shelly
opop2 a commencé à suivre Compteur shelly
Nouveau membre
DIO volets
DIO volets
denisg027 a commencé à suivre Home Assistant
Choix dongle usb zigbee
Zéro to Domo
Nouveau membre
